[GRASS-dev] Re: [GDAL] #1587: Error compiling gdal-grass against gdal 1.4.1
Markus Neteler neteler at itc.it
Wed Apr 25 15:00:47 EDT 2007
it is currently no more possible to compile the official
GRASS-GDAL-OGR plugin against GRASS 6.3-CVS. There is
a bug report open at GDAL:
http://trac.osgeo.org/gdal/ticket/1587
In summary, there a certain function definition needs
to be conditionalized upon the GRASS version but there
is the problem that it is defined as char in
include/version[.in].
Following question is open:
>  Reporter:  perrygeo     |        Owner:  mloskot
>      Type:  defect       |       Status:  reopened
>  Priority:  normal       |    Milestone:
> Component:  ConfigBuild  |      Version:  1.4.1
>  Severity:  normal       |   Resolution:
>  Keywords:  grass        |
> Comment (by mloskot):
>  Markus,
>  Would it be possible to have version definition as a preprocessor macro
>  instead of character object?
>  Ideally, I think it would be best if there is a version macro defined as a
>  number calculated as:
>  MAJOR * 100000 + MINOR * 100 + MICRO
>  what for '''6.3.0''' results as '''600300'''.
>  This way we have a value that can be easily calculated from version string
>  and makes it very easy to compare if one version is lower/higher from
>  another one.
>  What do you think?
> Ticket URL: <http://trac.osgeo.org/gdal/ticket/1587#comment:7>
> GDAL <http://trac.osgeo.org/gdal/>
> Geospatial Data Abstraction Library is a translator library for raster and vector geospatial data formats.
Please suggest - the result should then be posted into the
GDAL bugtracker (you need to register for this, see trac).
Markus
