[GRASS-dev] default display font selection in GUI
Glynn Clements
glynn at gclements.plus.com
Mon Apr 30 05:02:42 EDT 2007
Michael Barton wrote:
> I¹ve added a menu option (under configure) to make it easier to set the
> default font for displayed text in GRASS. It works pretty well with my Mac,
> but it needs to be tested on other systems. Currently it tries to get you to
> a reasonable possibility for a directory containing your fonts. On the Mac,
> it goes to /Library/Fonts, on Windows, it starts at $WINDIR/fonts, on other
> systems, it starts at /usr/lib/x11/fonts.
Note that it should be "X11" with an upper-case "X".
> If one of these directories does not contain your fonts, you can
> browse to it.
Does it handle the case where the directory doesn't exist? Gentoo
doesn't have /usr/lib/X11/fonts; fonts normally go into subdirectories
of /usr/share/fonts.
