[GRASS-dev] zomm issue with wx GUI
benjamin.ducke at ufg.uni-kiel.de benjamin.ducke at ufg.uni-kiel.de
Tue Aug 7 04:53:56 EDT 2007
I can confirm both these issues (on Gentoo Linux).
If I leave a wx monitor open, after I quit GRASS, I will
not be able to close it at all and have to kill the underlying
process. If however, I also leave the main manager window open,
then I will be able to close that and it will in turn close
open map windows, even if I exited the GRASS shell already.
I observe the same problem with zooming.
Additionally, the manual pages in the wx module dialogs do not
show any bitmaps. But this may be a problem with my own wxPython
setup.
Benjamin
> Just been paly around with the wx gui. Works fine, but there are some
> issues:
> if I hit crtl+d inthe terminal (as I usually do to exit grass), the
> gui remains open. and if I exit the gui (file-exit) the grass session
> remains open in the terminal.
> BTW, I am using it as the main gui, called from .grassrc6
> Now the main one. If I set the zoom to some map, I don't get the whole
> map in the display! see the pictures to compare what happens in wx and
> tcl guis
> http://www.igc.usp.br/pessoais/guano/temp/tcl.jpg
> http://www.igc.usp.br/pessoais/guano/temp/wx.jpg
> (I put the images in this server because I'm not sure whats the limit
> for the dev list, although they are quite small)
> Carlos
>               Carlos Henrique Grohmann - Guano
>   Visiting Researcher at Kingston University London - UK
>   Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
> Linux User #89721  - carlos dot grohmann at gmail dot com
> _________________
> "Good morning, doctors. I have taken the liberty of removing Windows
> 95 from my hard drive."
> --The winning entry in a "What were HAL's first words" contest judged
> by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
> Can't stop the signal.
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
