[GRASS-dev] GRASS 6.3.0 release preparation
    Paul Kelly
    paul-grass at stjohnspoint.co.uk
    Sun Aug 12 04:05:09 EDT 2007
On Sat, 11 Aug 2007, Glynn Clements wrote:
> Paul Kelly wrote:
>> I was just thinking, the Python GUI can probably be merged into the CVS
>> HEAD after a release branch has been created for 6.4.x (probably won't be
>> ready for that for at least a couple of months). Then there will be 6.5.x
>> - we can probably start making other major changes there and release it
>> eventually as 7.0? How does that sound?
> I'm disinclined towards the creation of 6.4/6.5 versions. I would
> prefer to see stable = 6.3.x, dev = 7.0-cvs.
But that breaks with our convention of having odd sub-versions (5.3, 6.1
etc.) for incremental releases of "under-development" versions and even
sub-versions (5.0, 5.4, 6.2 etc.) for releases of stable versions with
incremental bugfixes.
The way I see it, we should be making reasonably regular 6.3.x releases
right now from the CVS HEAD. These are just development releases, to
encourage people to test the latest developments, without having to get a
CVS version. I actually think there's a good argument for releasing
development versions at fixed intervals (e.g. every 2 months) - keeps
everything well tested, adds a bit of motivation for developers to finish
up new features shortly before a release is due and that kind of thing.
With that logic in mind I really think we should release 6.3.0 straight
away, right now - it isn't necessarily supposed to be totally stable - and
then release successive 6.3.x releases, if necessary, in the next couple
of months until we feel we're ready for a stable release - then we create
a branch in CVS and release 6.4.0 from that.
And after that the CVS HEAD is freed up to start putting major changes in.
What the next version is called is a different issue though, but I think
the move to SVN should be transparent and we don't need to use the actual
move as a tool to help out version control - the situation with the two
repositories for 5.0 and 6.0 resulted, as I understand it, because
development on 6.x (then called 5.1.x) started way before 5.0.x had had
its first stable release, and it was impractical to develop them both from
the same repository. I think we're better organised enough now not to have
to do that.
Anyway version numbering - I don't see how we can ever call the CVS HEAD
7.0-CVS - because 0 is an even number - 7.0-CVS implies incremental
bugfixes to an already-stable 7.0 version??? That's what it seems to me.
How would incremental development versions be numbered then? Considering
6.2-CVS and 5.4-CVS - those both correspond to ultra-stable CVS
branches that only have occasional bugfixes added to them. Much as in
5.7-CVS became the 6.0.0 stable release, it seems to me (or it *did* seem
like that ;) that after the 6.4 branch is created, the CVS becomes
6.5-CVS, and this eventually becomes 7.0.0. BUT that breaks with the logic
than changes in sub-version number should not result in major incompatible
changes. This seems to be a flaw in our version-numbering system that I
never noticed before, and I'm a bit stumped by it. Perhaps everyone else
realises it already and that's why no one else is as pedantic about the
version numbering as me.
I suppose the question really boils down to are we going to abandon the
sub-version numbering (odd development, even stable) system, or not? I feel
it hasn't been totally unsucessful, but we really should have made more
out of it by releasing more development versions. As far as I remember it
was supposed to be similar to the Linux kernel system, and wonder how they
handled the numbering of development releases before a major version
number change - but (a) I don't think there's been one in the last 9
years, the time I've been using Linux anyway and (b) I suspect their
system is also changing too as they find different ways of working.
Bernhard used to have some interesting thoughts about this sort of thing;
I wonder if he is still listening.
Anyway, I just wanted to make clear why I suggested a 6.4 release branch
followed by 6.5 CVS leading to 7.0.0. Although now I'm not quite as sure
what's the most logical way forward...
Paul
