[GRASS-dev] Launching GRASS 7 development
Helena Mitasova hmitaso at unity.ncsu.edu
Sun Aug 12 17:00:31 EDT 2007
On Aug 12, 2007, at 3:40 PM, Markus Neteler wrote:
>>> While we should concentrate now on getting out 6.3.0 (e.g.,
>>> fixing issues indicated by Helena [1]), it is important
>>> to start planning for a GRASS 7 dev-branch management.
>>> For GRASS 6, we used for quite some time a mixed solution,
>>> with new code stored in the grass6/ repository and linking
>>> old, relevant code from grass[5]/ into it using some link
>>> scripts.
>>> I am not sure if we want the same for grass7/, too.
>>> On the other hand, replicating code is impossible since
>>> it won't be well maintained given our limited resources.
>>> Thoughts also here?
>> I found the "make mix" mechanism to be a nuisance.
> Me, too.
>> Also:
>> 1. I was hoping to bulk-reformat the code with "indent" before we
>> started doing any actual work on it (so we need to finalise the
>> formatting conventions).
>> AFAICT, bulk reformatting is safe. Compiling without -g [1] and with
>> -DNODEBUG [2] then generating MD5 hashes for all of the .o files
>> produces the same hashes before and after reformatting.
>> [1] Debug information includes line numbers.
>> [2] -DNODEBUG disables the assert() macro, which uses __LINE__
> This sounds very good.
>> 2. Are we going to use CVS or Subversion for 7.x?
> My suggestion is to start new repository from scratch in SVN
> using the *migrated* CVS repos to maintain history. This is essential,
> also for copyright issues and other reasons. Moving files around in
> SVN
> is very easy (while it is not in CVS). The hassle of double
> maintenance
> (backporting) would remain of course.
> Since the CVS admins signalled to have no time for a migration,
> we can temporarily start on "my" own SVN server or ask for an
> OSGeo SVN server repository.
Markus - I suggest to avoid temporary solutions because they tend to
stick
around for years. Let us try the OSGeo SVN server if you think that
it will work
- that may help to test and build a strong OSGeo infrastructure.
Helena
> Still we have to figure out the flags of the cvs2svn conversion
> script.
> Markus
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
