[GRASS-dev] [grass-code I][458] 6.2 modules using new parser flags
Sun Aug 12 17:33:11 EDT 2007
Maciej Sieczka wrote:
> code I item #458, was opened at 2007-08-11 16:28
> Status: Open
> Priority: 2
> Submitted By: Scott Mitchell (smitch)
> Assigned to: Nobody (None)
> >Summary: 6.2 modules using new parser flags
> Issue type: module bug
> Issue status: fixed in CVS
> GRASS version: 6.2
> GRASS component: display
> >Operating system: all
> Operating system version:
> GRASS CVS checkout date, if applies (YYMMDD):
> >Comment By: Maciej Sieczka (msieczka)
> Date: 2007-08-11 22:44
> Message:
> I have checked current 6.2 CVS source and I can find no occurences of
> --q or --v flags in use by any modules.
The --q[uiet] and --v[erbose] flags are implemented by G_parser(), and
aren't present in 6.2.x.
I'm unsure whether to remove the --quiet flags only from the 6.2.x
version of d.slide.show, or also from the 6.3.x version.
IMHO, d.slide.show should simply allow the d.rast/d.vect commands to
operate at the verbosity level set by $GRASS_VERBOSE. If d.slide.show
itself is passed --q or --v, GRASS_VERBOSE will be set accordingly,
and the d.rast/d.vect commands will inherit that setting. Otherwise,
they will inherit any existing setting of $GRASS_VERBOSE.
Forcing the commands to operate quietly regardless of --v or any
$GRASS_VERBOSE setting seems incorrect.
