[GRASS-dev] BLAS/LAPACK (Part II)
Brad Douglas rez at touchofmadness.com
Fri Aug 17 00:09:44 EDT 2007
Hello,
I did not hear any response to my question of whether to continue using
BLAS/LAPACK.
This uncertainty has been particularly hard on me, being unable to
complete some work waiting for an answer one way or the other and not
wanting to implement my own version if not needed.
Currently, there is no code in the tree that makes use of either library
other than my own.  In fact, others have implemented their own versions.
What I propose is moving the matrix code from v.generalize (in
particular, matrix_inverse() ) to lib/gmath and simplifying the existing
MATRIX structure.
73, de Brad KB8UYR/6 <rez touchofmadness com>
