[GRASS-dev] Re: v.generalize and interpolation, dmax problem
Dylan Beaudette dylan.beaudette at gmail.com
Fri Aug 17 12:19:20 EDT 2007
On Friday 17 August 2007 02:21, Paul Kelly wrote:
> On Fri, 17 Aug 2007, Helena Mitasova wrote:
> [Interesting/impressive test results...]
> > which brings me to the main question - are there any objections to make
> > dmax default value
> > as large as the region to make sure that it does not add any points
> > (currently it is set to 1.25 resolution value which is obviously not
> > enough)? I have been trying to eliminate this parameter for years
> > as it usually causes more problems than it solves.
> For 7.x perhaps you could drop both the dmin and dmax parameters, and add
> a note to the man page suggesting that the user preprocess their contour
> data with v.generalize to resolve issues with closely-spaced points,
> before running v.surf.rst?
> Just a thought
> Paul
Helena:
Very interesting results- maybe consider writing this up in the OSGEO
journal ?
I agree with Paul, as I have struggled and fussed with those two options for
v.surf.rst for years.
Cheers,
Dylan
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
