[GRASS-dev] BLAS/LAPACK (Part II)
"Sören Gebbert" soerengebbert at gmx.de
Tue Aug 21 15:58:12 EDT 2007
Hi Daniel,
2007/8/20, Daniel Bundala <bundala at gmail.com>:
> Guys,
> It is quite interesting, but I have had plans to replace v.generalize
> matrix code by "yours" library code. I have not studied G_matrix_*
> code carefully, but it seems to me that it is superior.
Unfortunately there are two libraries which handle
the solution of linear equation systems.
The gmath library with the G_math_* and G_vector_* functions
and the higher level gpde library with several multi threaded solvers
(N_solver_cg ...).
I have implemented the matrix vector functionality in the gpde library
again, because i wanted them multi threaded and i have had no idea
if the gmath functions are thread safe and easy to parallele.
> Firstly, Soeren wrote that the current code is multithreaded.
Yes, the code from the gpde library is multi threaded, but you can
link parallelled lapack and blas libraries to the gmath interface (scalapack).
> Secondly, someone mentioned, that it supports the sparse matrices.
The gpde library supports a simple sparse matrix implementation
and the matrix vector product functions.
> Support of sparse matrices would increase the efficiency of
> v.generalize since it uses only the sparse matrices.
> Thirdly, Soeren mentioned that the current code supports many methods
> my code doesnt support. To tell the truth, I have never heard about
> many of them (Well, I am still (young) student...)
Of what kind are your matrices? There are two very efficient
solver within the gpde lib:
1.) for sparse symmetric and positive definite matrices (conjugate gradients
with preconditioning cg/pcg)
http://en.wikipedia.org/wiki/Conjugate_gradient_method
and
2.)for sparse non symmetric, non definite matrices (stabilized bi
conjugate gradients)
http://en.wikipedia.org/wiki/Biconjugate_gradient_method
Those two methods are the most efficient linear equation solvers
available for large matrices.
> The only thing I am missing in the current code is the direct access
> to the elements of a matrix. But, this is quite dangerous and I really
> doubt whether this is a good API-desing.
The matrix implementation within the gpde library offers direct access
to the matrix entries and supports row shuffling by setting the
row pointer (important for for pivoting). So the programmer
have to assure thread safe access by himself.
> On the other hand, it is true that the current code is quite obscure,
> say. Also, it is tempting to replace fortran code by C code.
> Therefore, my suggestons are: clean library code and replace the
> current code by v.generalize code only if it is really faster. Some
> benchmarks are probably required, but I doubt that my code beats
> (optimized) library code.
The gpde library implementation is IMHO not faster than
the gmath and BLAS/LAPACK stuff. Eg: the gmath lu solver
is 30% faster than the gpde lu solver with pivoting.
But the gmath lu solver is code from the numerical recipes,
we have to rewrite this method. And the gpde lu solver runs on
multi processor machines.
I will present an implementation of several matrix-vector functions
in some days. And I'm open for any suggestions about API design. :)
Best regards
Soeren
Psssst! Schon vom neuen GMX MultiMessenger gehört?
Der kanns mit allen: http://www.gmx.net/de/go/multimessenger
