[GRASS-dev] GRASS 6.3.0 release preparation
Massimo Di Stefano massimodisasha at yahoo.it
Thu Aug 23 07:27:34 EDT 2007
Hi  Michael
yes you're right it is my mistake
apologize me for this!
i'm uploading the cvs code using a bash script
in it i added a line that rename the gmmenu.tcl to
gmmenu_old.tcl and copy a local file "gmmenu.tcl" from
the previouse release in to the new
...really bud idea...
(this to preserve many changes that i done in the
gmmenu to add some script)
obviously i need to change this method :-/
thanks for the advice!
Massimo.
--- Michael Barton <michael.barton at asu.edu> ha
scritto:
> Massimo,
> I checked into these 2 GUI issues.
> #4) Works for me. It opens an xmon and a terminal
> with a prompt to pick a
> vector network map. Your description of the menu
> entry suggests that you are
> using an old version. I changed this menu entry
> several months ago when I
> shortened all menus and changed menu nesting to more
> more than 2 subentries
> deep. Now it should be vector->network
> analysis->display shortest route. Try
> updating to a current version and see if it fixes
> it. If not, we need to
> find out why the TclTk procedure guarantee_xmon is
> not producing a valid
> list of xmons using d.mon -L. Try this command and
> see what happens.
> #5) I have the same problem. It stems from the TclTk
> window being opened to
> exactly the pixel height that bisects the last
> checkbox control. I don't
> know why it is not opening a bit further by default.
> This is part of the
> autogenerated TclTk dialogs for GRASS commands. I
> only very generally know
> how this works. So I'm not sure how to fix it. I'll
> see if I can figure out
> what is setting the window height.
> Michael
      ___________________________________
L'email della prossima generazione? Puoi averla con la nuova Yahoo! Mail: http://it.docs.yahoo.com/nowyoucan.html
