[GRASS-dev] 6.3 release issue - d.nviz
Glynn Clements
glynn at gclements.plus.com
Sat Aug 25 23:47:22 EDT 2007
Michael Barton wrote:
> There is another small issue that needs to be fixed for the 6.3 release.
> I created a TclTk wrapper for d.nviz so that flythrough paths can be created
> interactively without an x11 terminal. But I discovered that there is a bug
> in d.nviz so that it won't create a script from entered xy path coordinates.
> It will only do a script from interactive mouse clicking in a terminal. I
> can't test and debug my TclTk code for d.nviz until it can accept xy
> coordinates for a path like it is supposed to.
> Glynn suggested a fix, but I can find it in my inbox.
This one?
http://grass.itc.it/pipermail/grass-dev/2007-August/032625.html
