[GRASS-dev] compilation of grass on solaris
Markus Neteler
neteler at itc.it
Tue Aug 28 08:55:20 EDT 2007
Hi Jachym,
this is related to (n)curses.
I found this thread:
http://www.webservertalk.com/archive100-2005-9-1216600.html
When configuring Mutt, Mutt doesn't find the <ncurses.h> because the
new version of ncurses install this header under <ncurses/ncurses.h>
(at least, under Solaris).
I dunno, but maybe check in this direction.
Ah, even better of course searching in this list:
http://www.nabble.com/Grass-6.0cvs-21-05-2005-on-Solaris-Sparc-tf30910.html#a92096
http://www.nabble.com/-GRASS5--binaries-for-5.0.3---1-for-testing-%28Linux%29%2C-2-%28Sun%2CMac%29-problems-tf3093099.html#a8586854
Markus
Jachym Cepicky-4 wrote:
> hi,
> i try to get GRASS 6.2.2. running on SunOS os-wrk2 5.10
> Generic_118833-20 sun4u sparc SUNW,A70 but the compilation failes
> ./configure --with-postgres-includes=/usr/include/pgsql/
> --with-fftw-includes=/usr/local/ --with-freetype
> --with-freetype-includes=/usr/local/include/freetype2/ --with-cxx
> --srcdir=`pwd` --with-fftw-libs=/usr/local/lib/ --with-fftw=no
> --with-png-libs=/usr/local/lib
> --with-zlib-includes=/usr/local/include/
> --with-zlib-libs=/usr/local/lib/
> --with-gdal=/usr/local/bin/gdal-config --with-nls --without-opendwg
> make
> [error in many modules]
> cd lib/init
> make
> gcc
> -L/export/home/meteo/src/grass/grass-6.3.cvs_src_snapshot_2007_08_25/dist.sparc-sun-solaris2.10/lib
> -Wl,-R,/export/home/meteo/src/grass/grass-6.3.cvs_src_snapshot_2007_08_25/dist.sparc-sun-solaris2.10/lib
> -o
> /export/home/meteo/src/grass/grass-6.3.cvs_src_snapshot_2007_08_25/dist.sparc-sun-solaris2.10/etc/set_data
> OBJ.sparc-sun-solaris2.10/set_data.o
> OBJ.sparc-sun-solaris2.10/mke_mapset.o
> OBJ.sparc-sun-solaris2.10/mke_loc.o
> OBJ.sparc-sun-solaris2.10/chk_dbase.o
> OBJ.sparc-sun-solaris2.10/other.o -lgrass_edit -lgrass_gis
> -lgrass_datetime -lnsl -I/usr/local/include/ -L/usr/local/lib/ -lz
> -lsocket -lgrass_vask -lgrass_gis -lgrass_datetime -lnsl
> -I/usr/local/include/ -L/usr/local/lib/ -lz -lsocket
> -lgrass_datetime -lgrass_vask -lncurses -lm -lnsl
> Undefined first referenced
> symbol in file
> initscr32
> /export/home/meteo/src/grass/grass-6.3.cvs_src_snapshot_2007_08_25/dist.sparc-sun-solaris2.10/lib/libgrass_vask.so
> w32addch
> ld: fatal: Symbol referencing errors. No output written to
> collect2: ld returned 1 exit status
> make: ***
> [/export/home/meteo/src/grass/grass-6.3.cvs_src_snapshot_2007_08_25/dist.sparc-sun-solaris2.10/etc/set_data]
> Error 1
> echo $LD_LIBRARY_PATH
> /usr/local/lib:/usr/sfw/lib/:/usr/lib/:/usr/xpg4/lib/
> could anybody give me a hint, how to approach?
> thanks
> jachym
> Jachym Cepicky
> e-mail: jachym.cepicky gmail com
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
View this message in context: http://www.nabble.com/compilation-of-grass-on-solaris-tf4340879.html#a12367417
Sent from the Grass - Dev mailing list archive at Nabble.com.
