[GRASS-dev] [grass-code I][470] i.atcorr: hardcoded input/output
map names
Maciej Sieczka
tutey at o2.pl
Wed Aug 29 15:49:13 EDT 2007
Yann wrote:
> Hi Maciek:
> Line 221-222 in main.cpp:
> ialt_fd: height map file descriptor, negative if global value is
> used ivis_fd: visibility map file descriptor, negative if global
> value is used
Yann,
Thanks. I don't know C. I'm no programmer. Can you please say which one
- the raster or the value in the i.attcor config file takes precedence?
What happens if both are specified?
Maciek
