[GRASS-dev] Re: [GRASS-user] GRASS6.3 on Windows
Paul Kelly paul-grass at stjohnspoint.co.uk
Fri Aug 31 16:27:40 EDT 2007
Hello Michael
On Sat, 25 Aug 2007, Michael Barton wrote:
> Moritz,
> Update /gui/tcltk/gis.m/runandoutput.tcl from the cvs and see what happens.
> I just made a change, suggested by Glynn, that fixed similar symptoms for
> with with another command (v.what). v.what was kicking out extraneous
> information when it launched and creating an identical dialog. I've
> separated out stderr from the normal stdout information when commands are
> launched from the menu and it works fine now.
As far as I can see there in that latest change you're redirecting stderr
to /dev/null. So now there will be no output for the catch command to
catch in case of an error - so printing out the error message is
pointless. In any case a popup dialog should be a better option than
printing to the terminal where the user might not notice it until later -
or in future there may not even be a terminal, e.g. in WinGRASS but maybe
we'll change that.
I'd suggest using the catch command something as follows (this is adapting
what's in epsg_option.tcl):
catch {set code [exec -- $program --tcltk]} errMsg
if {[lindex $::errorCode 0] eq "CHILDSTATUS"} {
     DialogGen .wrnDlg [G_msg "Error running command!"] warning \
     [format [G_msg "%s returned the following message:\n%s"] $program $errMsg] \
     0 OK
} elseif {$errMsg != ""} {
         DialogGen .wrnDlg [format [G_msg "Informational output from %s"] $program] info \
         [format [G_msg "%s returned the following informational message:\n%s"] $program $errMsg] \
         0 OK
DialogGen is a nice little routine in gis_set.tcl that pops up a dialog
box. There are some comments in gis_set.tcl on how to use it.
Please note that I'm not saying this is what you should do, nor that I
necessarily recommend doing it now - my original comments about catching
errors properly where really just suggestions about something that we
should look out for in the future, as I thought it would be too much work
do do it thoroughly and properly now so soon before 6.3.0 without
introducing new unexpected behaviour and so on.
Possible problems with and notes about the above code:
- With the catch where it is - I'm not sure if it actually catches the
"exec" command or just the "set" command
- Checking the return status of the command is better than checking the
return value of catch, because, as we've seen lots of times - Tcl will
assume an error has happened if *any* output is written to stderr - a
usage convention not shared by GRASS.
- Output issued to stderr but when the command has exited successfully
should be handled by the second block of the if statement, and popped up
for the user to read and then continue.
- To be neater and less confusing to the user, the possiblity of a command
exiting with a non-zero return code but not writing anything to stderr
should probably also be handled.
Paul
