[GRASS-dev] things to do before the 6.3.0 release
Martin Landa landa.martin at gmail.com
Tue Dec 18 08:17:34 EST 2007
2007/12/18, Hamish <hamish_b at yahoo.com>:
> Martin Landa  wrote:
> > it should be fixed now in trunk (since I don't know g.setproj, please
> > take a look), I left the ticket open since I am not sure if we can
> > uncomment ch1903 item in lib/gis/datumtransform.table.
> > See diff (sorry, I didn't split the patch, next time...:-)
> > http://trac.osgeo.org/grass/changeset/29468
> > @@ -455,5 +455,7 @@
> >               /* don't ask, use the default */
> > -             if (G_strcasecmp(desc->type, "float") == 0) {
> > +             if (G_strcasecmp(desc->type, "float") == 0 ||
> > +                 G_strcasecmp(desc->type, "lat") == 0 ||
> > +                 G_strcasecmp(desc->type, "lon") == 0) {
> >                   sprintf(tmp_buff, "%.10f", parm->deflt);
> >                   G_set_key_value(desc->key, tmp_buff, out_proj_keys);
Hamish:
> would you explain the logic of the fix? it is not obvious to me, but
> superficially lat,lon seems outside the set of float,int. I am trying
> to understand if this is a proper fix or a hack which works around a
> corner case. ie it may be a fix, but is it the right one?
Since desc->type has been checked only for 'int' and 'float', a key
with type 'lat' or 'lon' was simply ignored. lat,lon type is checked
in interactive mode (parm->ask), but it wasn't checked for
parm->def_exists.
408 	                else if (G_strcasecmp(desc->type, "lon") == 0) {
409 	                    double val;
410 	                    while (!get_LL_stuff(parm, desc, 0, &val)) ;
411 	                    sprintf(tmp_buff, "%.10f", val);
412 	                    G_set_key_value(desc->key, tmp_buff, out_proj_keys);
413 	                }
414 	                else if (G_strcasecmp(desc->type, "float") == 0) {
415 	                    double val;
416 	                    while (!get_double(parm, desc, &val)) ;
417 	                    sprintf(tmp_buff, "%.10f", val);
418 	                    G_set_key_value(desc->key, tmp_buff, out_proj_keys);
419 	                }
Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
