[GRASS-dev] Re: test of v.area.thematic
Moritz Lennert mlennert at club.worldonline.be
Sun Dec 30 15:21:01 EST 2007
On 29/12/07 20:20, Michael Barton wrote:
> Moritz,
> Couldn't help myself and tried out the new v.area.thematic.
> I very much like it, but there is something not working about the color
> assignments. I tried the following, using the new NC GRASS demo data set.
> GRASS 6.3.svn (nc_spm_07):~ > d.area.thematic map=censusblk_swwake
> data=total_pop breaks='v.class map=censusblk_swwake column=total_pop
> algo=std nbcla=4' colors=0:0:255,0:0:100,100:0:0,255:0:0 layer=1
> bwidth=0 bcolor=yellow render=l
> v.class shows the following
>  From            To              Frequency
> 0.000000        20.208039       1136
> 20.208039       63.030745       779
> 63.030745       105.853451      270
> 105.853451      6173.000000     1136
> But the map only shows 2 colors (blue and dark blue). Everything else I
> try only shows 2 colors, whether I use GRASS standard colors or RGB
> designations.
Thanks for testing. I'll look into this.
Moritz
