[GRASS-dev] [bug #5463] (grass) v.in.dxf support for spaces in layer names
Markus Neteler neteler at itc.it
Fri Feb 2 05:07:54 EST 2007
Request Tracker wrote on 02/02/2007 05:32 AM:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5463
> Subject: v.in.dxf support for spaces in layer names
> v.in.dxf fails to load in DXF layers which include spaces in their names.
> it fails during the SQL create table step.
> Is there a lib fn to SQL-proof layer names? (eg v.in.ascii, v.in.ogr space ->
> underscore)
See main.c of v.in.ogr, around line 586.
That part might be moved up to library level.
Markus
