[GRASS-dev] Re: Wxgrass status update
Jáchym Čepický jachym.cepicky at centrum.cz
Fri Feb 2 05:51:36 EST 2007
hi Michael,
2007/2/1, Michael Barton <michael.barton at asu.edu>:
> Jachym,
> I did a quick glance and it looks like it will make working with display
> layers much easier. Options panels can use these classes to define how
> layers should be displayed.
> Somewhere we'll need to wrap this code into the integrated application. This
> module is called render.py in my version--the one that I proposed renaming.
> Maybe disputil.py would make more sense in the long run. I'm not sure yet
> how much we should split up different functions into distinct smaller
> modules and how much they should be expressed as classes in included in
> larger modules.
> As we go along, we should keep trying to refactor like you've done here, and
> produce clean code that will be easier to maintain in the future. I've
> become acutely aware of this after untangling a lot of ancient TclTk
> spaghetti code (some of it not so ancient and mine).
> Cheers
> Michael
If you don't mind, I would start over the weekend or on Monday to
rewrite mapdispl.py, so it uses new mapimg.py  (maybe it should be
renamed to maprender.py?).
Jachym
> On 2/1/07 1:45 AM, "Jáchym Čepický" <jachym.cepicky at centrum.cz> wrote:
> > hi Michael, it is good, that you are back!
> >>  Jachym,
> >>  I'm actually working with wx.Python again. Thank goodness it is starting to
> >> come back to me after a 5 month hiatus. I decided to just focus on the
> >> mundane tasks of the layer manager. This is good practice for me and pretty
> >> straightforward in many respects, though sufficiently challenging (ie.,
> >> difficult) that progress remains slow--for me at least. And I've only got
> >> bits and pieces of time to devote to this at the moment.
> >>  What I've got now is a wx.Choicebook with a page for each display opened.
> >> On that page is a wx.Notebook with a layer tree (at least theoretically
> >> since I'm still trying to make it work) notebook page and a command console
> >> notebook page. Each layer (i.e., node in the tree) will need a way to
> >> indicate the name of the map in the layer, some indication (e.g., an icon)
> >> of whether it is raster or vector (or something else), a way to make the
> >> layer active/inactive, and some way to call up a panel to set the display
> >> options for the layer. It looks like wx.CustomTreeCtrl will work quite well
> >> for this. Once I get that far, I'll put it up on the cvs so that anyone can
> >> play with it. If you'd like to see where I'm at any time, just let me know
> >> and I'll send you some files.
> >>  One other thing is that the render.py module has become a handy place to
> >> stash a few methods to track open displays, related variables, and the like
> >> so that they don't instantiate new displays or control panels when
> >> called--along with other display rendering functions. If it continues to
> >> serve in this way, do you think we should rename it to something like
> >> mapfunct.py or multifunct.py???
> >>  Just wanted to bring you up to date. Hope your trip is going well.
> >>  Cheers
> >>  Michael
> >>  __________________________________________
> >>  Michael Barton, Professor of Anthropology
> >>  School of Human Evolution & Social Change
> >>  Center for Social Dynamics & Complexity
> >>  Arizona State University
> >>  phone: 480-965-6213
> >>  fax: 480-965-7671
> >>  www: http://www.public.asu.edu/~cmbarton
> > I started to define new set of classes, which should be easy to use
> > and more logical orderd.
> > Please look at the
> > https://grasssvn.itc.it/grasssvn/grassaddons/trunk/grassaddons/gui/#_trunk_gra
> > ssaddons_gui_
> > you can test it with
> > python mapimg.py
> > and see the documentation with
> > pydoc ./mapimg.py
> > How to work with it, look at the end of mapimg.py
> > Idea is, that each Map has defined set of layers (rasters, vectors,
> > graphs, WMS, WCS, ...). This set of layers should be taken over by
> > each Display.
> > Let me know, if you like it
> > I moved the work to grasssvn-addons repository, because this are all
> > fresh ideas and the code is not mature yet. Ones we have basic working
> > GUI, we shoul reorganize gui/wxpython directory. subversion anables us
> > to rename the files and so on.
> > I hope, you like it
> > Jachym
> > P.S. I Sent this e-mail in a copy to Martin Landa - second GUI developer.
> phone: 480-965-6213
> fax: 480-965-7671
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
