[GRASS-dev] [bug #5471] (grass) d.vect too noisy
Martin Landa landa.martin at gmail.com
Mon Feb 5 05:06:49 EST 2007
I think it could be removed. If not I can imagine
WARNING: Line color and *default* background color are the same
only in *MAXLVEL* of verbosity. But I am not sure if this warning
makes sense to the user.
Martin
2007/2/5, Glynn Clements <glynn at gclements.plus.com>:
> Request Tracker wrote:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=5471
> > Subject: d.vect too noisy
> > G63> d.erase
> > G63> d.rast elevation.dem
> > G63> d.vect bugsites icon=basic/diamond col=white fcol=red
> > WARNING: Line color and background color are the same!
> > or
> > G63> d.erase blue
> > If that warning needs to exist at all, it should check to see if the monitor
> > command list is empty or there are no raster maps displayed (eg d.what.rast)
> > before doing so.
> That still won't catch the case where you're using the PNG driver with
> GRASS_BACKGROUNDCOLOR or GRASS_TRANSPARENT. There are probably other
> similar cases.
> IMHO, the warning should simply be removed.
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
