[GRASS-dev] v.db.dropcol added
John Gillette JGillette at rfmd.com
Mon Feb 5 11:48:24 EST 2007
Hi Markus,
I looked at you script without actually running it.  I have a few
questions (which may or may not be good).
(1) You check for an error in the non-sqlite case.  Shouldn't you also
check in the sqlite case?
(2) If there is an error, the script exits before erasing the TMP files.
Shouldn't you erase these even if there is an error?
(3) I think you missed $TMP.coldesc.  You want to erase that one too?
Thanks for all your hard work.
John
> -----Original Message-----
> From: grass-dev-bounces at grass.itc.it
> [mailto:grass-dev-bounces at grass.itc.it] On Behalf Of Markus Neteler
> Sent: Monday, February 05, 2007 8:27 AM
> To: grass developers list
> Subject: [GRASS-dev] v.db.dropcol added
> Hi,
> thanks to the new ALTER TABLE DROP COLUMN addition for the
> DBF driver, I have submitted a new "v.db.dropcol" script to
> CVS. It includes extra code for SQLite DBs since SQLite
> doesn't originally support column dropping. Using
> "v.db.dropcol", however, you can drop columns in any GRASS
> table connected to a vector map. Testing obviously welcome.
> cheers
> Markus
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
