[GRASS-dev] [bug #5481] (grass) BFD 2.16.91.0.7 20060317 internal error, aborting at elfcode.h
Request Tracker grass-bugs at intevation.de
Tue Feb 6 12:14:32 EST 2007
this bug's URL: http://intevation.de/rt/webrt?serial_num=5481
Subject: BFD 2.16.91.0.7 20060317 internal error, aborting at elfcode.h
Platform: GNU/Linux/x86_64
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: grass 6.2.1 (2006)
I've got this message in a make >& make.out
gcc -shared -o /usr/local/src/grass-6.2.1/dist./lib/libgrass_gproj.6.2.1.so -L/usr/local/src/grass-6.2.1/dist./lib -Wl,--export-dynamic -Wl,-rpath-link,/usr/local/src/grass-6.2.1/dist./lib    OBJ./get_proj.o OBJ./do_proj.o OBJ./convert.o OBJ./datum.o OBJ./ellipse.o -lgrass_gis -lgrass_datetime -lz     -lproj  -L/usr/lib64 -lgdal && if [ -z "" ] ; then ln -f -s libgrass_gproj.6.2.1.so /usr/local/src/grass-6.2.1/dist./lib/libgrass_gproj.so; fi
/usr/bin/ld: BFD 2.16.91.0.7 20060317 internal error, aborting at elfcode.h line 190 in bfd_elf64_swap_symbol_in
/usr/bin/ld: Please report this bug.
collect2: ld returned 1 exit status
make[2]: *** [/usr/local/src/grass-6.2.1/dist./lib/libgrass_gproj.6.2.1.so] Error 1
make[2]: se sale del directorio `/usr/local/src/grass-6.2.1/lib/proj
I configured with ./configure --prefix=/usr/local --enable-64bit --with-postgres-includes=/usr/include/pgsql --enable-shared
Anyway, I've could compile GRASS, but with I push enter button in the splash-project window a child killed segmentation violation it's produced (the console still go on, with some commands).
I wish this can be helpful for you. Best Regards,
Miriam
-------------------------------------------- Managed by Request Tracker
