[GRASS-dev] r.gwflow and r3.gwflow compile errors
Soeren Gebbert soerengebbert at gmx.de
Thu Feb 8 17:03:43 EST 2007
it looks like the linker is not able to find the new gpde library.
Maybe the lib was not build?
I will try to reproduce and fix this.
Maybe i should remove the new modules from the Makefiles .... .
Regards
Soeren
Am Donnerstag, 8. Februar 2007 22:44 schrieb Scott Mitchell:
> I just updated my grass6-cvs to check out the r.li - but two other
> modules didn't compile, the new gwflow.
> [smitch at gracilis r.gwflow]$ make
> gcc -L/fc2root/home/smitch/src/cvsgrass/grass6/dist.i686-pc-linux-gnu/
> lib -Wl,--export-dynamic -Wl,-rpath-link,/fc2root/home/smitch/src/
> cvsgrass/grass6/dist.i686-pc-linux-gnu/lib        -DPACKAGE=
> \""grassmods"\" -o /fc2root/home/smitch/src/cvsgrass/grass6/dist.i686-
> pc-linux-gnu/bin/r.gwflow OBJ.i686-pc-linux-gnu/main.o  -lgrass_gis -
> lgrass_datetime -lz      -lm  -lz
> OBJ.i686-pc-linux-gnu/main.o: In function `create_solve_les':
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:503:
> undefined reference to `N_assemble_les_2d'
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:514:
> undefined reference to `N_solver_bicgstab'
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:517:
> undefined reference to `N_solver_lu'
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:511:
> undefined reference to `N_solver_cg'
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:520:
> undefined reference to `N_solver_gauss'
> OBJ.i686-pc-linux-gnu/main.o: In function `copy_result':
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:484:
> undefined reference to `N_put_array_2d_value_dcell'
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:468:
> undefined reference to `N_get_array_2d_value_dcell'
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:477:
> OBJ.i686-pc-linux-gnu/main.o: In function `write_result':
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:431:
> OBJ.i686-pc-linux-gnu/main.o: In function `fill_array_2d':
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:387:
> OBJ.i686-pc-linux-gnu/main.o: In function `main':
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:215:
> undefined reference to `N_alloc_geom_data'
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:225:
> undefined reference to `N_alloc_les_callback_2d'
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:226:
> undefined reference to `N_callback_gwflow_2d'
> undefined reference to `N_set_les_callback_2d_func'
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:229:
> undefined reference to `N_alloc_gwflow_data2d'
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:326:
> undefined reference to `N_free_les'
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:328:
> undefined reference to `N_free_gwflow_data2d'
> /fc2root/home/smitch/src/cvsgrass/grass6/raster/r.gwflow/main.c:290:
> collect2: ld returned 1 exit status
> make: *** [/fc2root/home/smitch/src/cvsgrass/grass6/dist.i686-pc-
> linux-gnu/bin/r.gwflow] Error 1
> Same general problem in the 3D version.  I do have the header files
> for these functions, as far as I can tell.
> Does this look familiar to anyone?  Suggestions?
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
