[GRASS-dev] r.gwflow and r3.gwflow compile errors
Markus Neteler neteler at itc.it
Fri Feb 9 03:08:14 EST 2007
Hamish wrote on 02/09/2007 02:20 AM:
> Soeren Gebbert wrote:
>> it looks like the linker is not able to find the new gpde library.
>> Maybe the lib was not build?
>> I will try to reproduce and fix this.
> They build fine for me. Scott, did you run "make distclean" before
> rebuilding from the latest CVS?
Right, this is needed since the initial "make" step after "configure"
copies some include files into the right place.
I got into the same trap first, then remembered
  "if in doubt, run'make distclean'"
which solved the problem. I have compiled it successfully on 32 and
64bit machines.
Markus
