[GRASS-dev] [bug #5494] (grass) grass-6.2.1-1suse10.2.x86_64.rpm, failed dependencies: libmysqlclient.so.15
Moritz Lennert mlennert at club.worldonline.be
Mon Feb 12 16:44:09 EST 2007
On Mon, February 12, 2007 22:11, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5494
> Subject: grass-6.2.1-1suse10.2.x86_64.rpm, failed dependencies:
> When I tried to install the binaries for GRASS 6.2.1 (together with geos,
> gdal, proj) I got the rpm error message "Failed dependencies" for
> libmysqlclient.so.15 and libpng12.so.0. But I have both.
> root:/download> rpm --install --test *.rpm
>  error: Failed dependencies:
>   libmysqlclient.so.15(libmysqlclient_15)(64bit) is needed by grass-6.2.1-
> 1suse10.2.x86_64
>   libpng12.so.0(PNG12_0)(64bit) is needed by grass-6.2.1-1suse10.2.x86_64
> root:/download> rpm -q --whatprovides libmysqlclient.so.15
>   mysql-shared-32bit-5.0.18-16
You are trying to install a 64bit version of GRASS which needs the 64bit
version of the libraries, but your mysql is 32bit.
Moritz
