[GRASS-dev] Re: winGRASS
Moritz Lennert mlennert at club.worldonline.be
Wed Feb 14 08:23:15 EST 2007
On 14/02/07 11:57, Glynn Clements wrote:
> Moritz Lennert wrote:
>> Now g.manual starts in its original form (no playing around with g.parser
>> calls), but I get:
>> g.manual entry=d.vect
>> Starting browser <url_handler.bat> for module d.vect...
>> url_handler.bat file://c:/GRASS/grass-6.3.cvs/docs/html/d.vect.html
>> And then nothing happens.
> Does running the command directly from a command prompt work? It's
> possible that the MSys shell is interfering in some way.
Yes, running
launches my default browser with the d.vect man page.
Concerning the wrong setting for GISRC, this seems to come from the
following line in etc/Init.bat:
set WINGISRC=%HOME%\.grassrc6
'echo %HOME%' just results in %HOME%. Is HOME a valid Win env variable
(and what would $HOME actually be in a windows environment) ?
Moritz
