[GRASS-dev] Re: [GRASS-user] Re: Cygwin winGRASS 6.2 Errors!
[SUCESS}
Hamish
hamish_nospam at yahoo.com
Thu Feb 15 01:44:23 EST 2007
In scanning through the --helps to see if the cygwin modules worked
I found it got stuck on i.ortho.photo. I've now changed the main menu of
that to use G_parser().
(the i.ortho.photo menu could easily be rewritten BTW, it just lists 8
programs and runs the one you ask for. But then the ones it calls will
generally call I_ask() and want a interactive terminal, so there might
be little gained in the short term..)
remaining modules not using the parser:
d.rast.edit
g.parser
g.setproj
r.mapcalc
slowly getting there...
Hamish
