[GRASS-dev] r.flow with barrier fails
Jáchym Čepický jachym.cepicky at gmail.com
Mon Feb 19 06:51:20 EST 2007
Hi, r.flow fails, when used with barrin option:
r.flow elevin=elevation.dem barin=roads flout=streams
Reading input files: elevation
Reading input files: barrier
Segmentation fault
that is, because dsout option is not defined and read_input_files()
(io.c) tryes to store something in ds structure
when dsout option is defined, you get no reasonable result:
r.flow elevin=elevation.dem barin=roads flout=streams dsout=density
d.rast density
what to do?
thanks
jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
