[GRASS-dev] g.copy rast=
Martin Rutzinger Martin.Rutzinger at uibk.ac.at
Mon Feb 19 08:51:45 EST 2007
GRASS 6.3.cvs (utm):~ > gdb `which g.copy`
(gdb) run "rast=rott_one,test1"
Starting program: /usr/local/grass-6.3.cvs/bin/g.copy "rast=rott_one,test1"
[Thread debugging using libthread_db enabled]
[New Thread -1208944944 (LWP 13355)]
Copy <rott_one at hohenems_site> to current mapset as <test1>
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1208944944 (LWP 13355)]
do_copy (n=0, old=0xa02b838 "rott_one", mapset=0xa02b870 "hohenems_site",
new=0xa02b848 "test1") at do_copy.c:40
40              for (i = 0; i < list[n].nelem; i++)
(gdb)
Zitat von Martin Landa <landa.martin at gmail.com>:
> Hi,
> it is strange, on my machine g.copy works. What does gdb say?
> Martin
> 2007/2/19, Martin Rutzinger <Martin.Rutzinger at uibk.ac.at>:
> > hi list,
> > with the recent cvs version of grass63 g.copy for raster maps doesn't work
> any
> > more. i just get a meaningless 'memory access error'
> (speicherzugriffsfehler).
> > runinng configure, make, make install gives no error messages.
> > g.gisenv set="DEBUG=5"
> > g.copy rast=raster1,raster2
> > D3/5: Copy rast
> > Copy <raster1 at hohenems_site> to current mapset as <raster2>
> > Speicherzugriffsfehler
> > r.info raster2
> > D2/5: G__home home = /home/rusch
> > WARNUNG: Kann Header-Datei [raster2 in hohenems_site] nicht öffnen
> > WARNUNG: Kategorie Unterstützung für [raster2] im Mapset [hohenems_site]
> >          missing
> > WARNUNG: Kann die History-Informationen der Karte [raster2] in Mapset
> >          [hohenems_site] nicht finden.
> > WARNUNG: Kann range Datei für [raster2 in hohenems_site] nicht lesen.
> > FEHLER: Kann die Wertespanne nicht lesen.
> > the problem appears on FC4,FC5 and FC6 aswell with following configuration:
> > FLAGS='-g -Wall' ./configure  --with-x --enable-shared --with-proj
> > --with-gdal=/usr/local/bin/gdal-config
> --with-tcltk-includes=/usr/local/include
> > --with-postgres-includes=/usr/local/pgsql/include
> > --with-postgres-libs=/usr/local/pgsql/lib
> > --with-freetype-includes=/usr/include/freetype2
> --with-freetype-libs=/usr/lib
> > --enable-largefile --with-odbc --with-motif  --with-freetype=yes --with-cxx
> > --with-glw --with-nls --with-blas --with-lapack
> > --with-lapack-libs=/usr/local/lib --with-ffmpeg
> > --with-ffmpeg-includes=/usr/local/include/ffmpeg --with-sqlite
> > --with-proj-share=/usr/local/share/proj/ --enable-64bit --with-python
> > i don't know which libs/pkg are used by g.copy; but i tried different
> versions
> > of e.g. gdal ( gdal-1.3.2/gdal-1.4.0/gdal-svn; tcl/tk8.5a5/tcl/tk8.4.14)
> but it
> > seems to me that it's not dependent on a certain version of a package.
> > thanks alot!
> > martin
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
