[GRASS-dev] [grass-code I][303] Error trying to "Change region settings"
grass-codei at wald.intevation.org grass-codei at wald.intevation.org
Tue Feb 20 15:02:18 EST 2007
code I item #303, was opened at 2007-02-20 21:02
Status: Open
Priority: 3
Submitted By: Carlos Dávila (carluti)
Assigned to: Nobody (None)
Summary: Error trying to "Change region settings"
Issue type: None
Issue status: None
GRASS version: CVS HEAD
GRASS component: gis.m
Operating system: Linux
Operating system version: debian testing 2.6.18-3-486
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
In GIS Manager, if I choose the menu option Setting->Region->Change region settings, I get an error (see debug output below). I think it's due to some problem in the translation, as error title includes a translated word in the problem (existe instead of exist), but I'm not able to find the problem in po files.
Error output:
unknown option "existe.optwin"
    while executing
"Widget::init ScrolledWindow $path $args"
    (procedure "ScrolledWindow::create" line 4)
    invoked from within
"ScrolledWindow::create .dialog1.nb.fYa existe.optwin -relief sunken -borderwidth 2"
    ("eval" body line 1)
    invoked from within
"eval ScrolledWindow::create $path $args"
    (procedure "ScrolledWindow" line 1)
    invoked from within
"ScrolledWindow $optpane.optwin -relief sunken -borderwidth 2"
    (procedure "layout_make_frame" line 21)
    invoked from within
"layout_make_frame $dlg $guisection $optn"
    (procedure "layout_get_frame" line 4)
    invoked from within
"layout_get_frame $dlg $opt($dlg,$optn,guisection) $optn"
    (procedure "add_flag" line 19)
    invoked from within
"add_flag 1 {
 name {d}
 desc {Establecido de la región predeterminada}
 answer 0
 label {}
 guisection {Ya existe}
    ("eval" body line 6)
    invoked from within
"eval $code"
    (procedure "run_ui" line 10)
    invoked from within
"run_ui $cmd"
    (procedure "execute" line 3)
    invoked from within
"execute g.region "
    invoked from within
".#menubar.#menubar#options.#menubar#options#menu1 invoke active"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 [list $w invoke active]"
    (procedure "tk::MenuInvoke" line 50)
    invoked from within
"tk::MenuInvoke .#menubar.#menubar#options.#menubar#options#menu1 1"
    (command bound to event)
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=303&group_id=21
