[GRASS-dev] Modules
Thu Feb 22 21:48:21 EST 2007
Glynn Clements wrote:
> The remaining step is to reinstate the bgcmd= option.
Done; updated patch (again, against CVS HEAD) attached.
? OBJ.i686-pc-linux-gnu
? changes.diff
? round.diff
Index: attr.c
RCS file: /grassrepository/grass6/vector/v.digit/attr.c,v
retrieving revision 1.12
diff -u -r1.12 attr.c
--- attr.c	21 Feb 2007 22:15:41 -0000	1.12
+++ attr.c	23 Feb 2007 02:27:33 -0000
@@ -255,11 +255,11 @@
     return 1;
-int display_cats(void)
+void display_cats(void)
-    struct display_cats dc;
+    static struct display_cats dc;
-    return do_tool(display_cats_begin, display_cats_update, display_cats_end, &dc);
+    set_tool(display_cats_begin, display_cats_update, display_cats_end, &dc);
 /* Copy categories from one feature to another */
@@ -398,11 +398,11 @@
     return 1;
-int copy_cats(void)
+void copy_cats(void)
-    struct copy_cats cc;
+    static struct copy_cats cc;
-    return do_tool(copy_cats_begin, copy_cats_update, copy_cats_end, &cc);
+    set_tool(copy_cats_begin, copy_cats_update, copy_cats_end, &cc);
 /* Display attributes */
@@ -549,11 +549,11 @@
     return 1;
-int display_attributes(void)
+void display_attributes(void)
-    struct display_attributes da;
+    static struct display_attributes da;
-    return do_tool(display_attributes_begin, display_attributes_update, display_attributes_end, &da);
+    set_tool(display_attributes_begin, display_attributes_update, display_attributes_end, &da);
Index: c_face.c
RCS file: /grassrepository/grass6/vector/v.digit/c_face.c,v
retrieving revision 1.17
diff -u -r1.17 c_face.c
--- c_face.c	4 May 2006 19:37:26 -0000	1.17
+++ c_face.c	23 Feb 2007 02:27:34 -0000
@@ -20,7 +20,7 @@
 c_cancel ( ClientData cdata, Tcl_Interp *interp, int argc, char *argv[])
     G_debug (3, "c_cancel()");
-    R_set_cancel ( 1 );
+    cancel_tool ();
     Tool_next = TOOL_NOTHING;
     return TCL_OK;
@@ -90,8 +90,9 @@
     G_debug (2, "  Tool_next = %d", Tool_next);
     /* Stop running if any */
+    cancel_tool ();
+    next_tool();
     return TCL_OK;
Index: centre.c
RCS file: /grassrepository/grass6/vector/v.digit/centre.c,v
retrieving revision 1.16
diff -u -r1.16 centre.c
--- centre.c	31 Aug 2006 05:59:20 -0000	1.16
+++ centre.c	23 Feb 2007 02:27:34 -0000
@@ -18,149 +18,167 @@
 #include <stdlib.h>
 #include <unistd.h>
 #include <grass/config.h>
-#ifdef HAVE_NANOSLEEP
-#include <time.h>
-#endif
 #include <grass/gis.h>
 #include <grass/display.h>
+#include <grass/glocale.h>
 #include "global.h"
 #include "proto.h"
 /* This function is started from the GUI, it regularly updates GUI and checks GUI requirements.
 *  If Tool_next is set by GUI, the tool is started by the tool_centre()
-int
+void
 tool_centre ( void )
-    int go = 1;
+    symb_init_gui ();
+    i_prompt ( "Select tool");
-    symb_init_gui ( );
+    /* Init variables */
+    var_init ();
+    /* Init snap */
+    var_seti ( VAR_SNAP, 1 );
+    var_seti ( VAR_SNAP_MODE, SNAP_SCREEN );
+    var_seti ( VAR_SNAP_SCREEN, 10 );
+    var_setd ( VAR_SNAP_MAP, 10 );
+    G_get_window(&window);
+    /* Set tool */
+    Tool_next = TOOL_NOTHING;
-    while ( go ) {
-        G_debug (5, "Tool centre: Tool_next = %d", Tool_next);
-        i_update(); /* Let GUI set requests */
-	switch ( Tool_next ) {
-	    case TOOL_EXIT :
-                G_debug (2, "Quit" );
-		go = 0;
-		break;
-	    case TOOL_NEW_POINT :
-		/* Tool_next = TOOL_NOTHING; */ /* Commented -> Draw next one once first is done */
-		new_line ( GV_POINT );
-		break;
-	    case TOOL_NEW_LINE :
-		new_line ( GV_LINE );
-		break;
-	    case TOOL_NEW_BOUNDARY :
-		new_line ( GV_BOUNDARY );
-		break;
-	    case TOOL_NEW_CENTROID :
-		new_line ( GV_CENTROID );
-		break;
-	    case TOOL_MOVE_VERTEX :
-		Tool_next = TOOL_NOTHING;
-		move_vertex ();
-		break;
-	    case TOOL_ADD_VERTEX :
-		add_vertex ();
-		break;
-	    case TOOL_RM_VERTEX :
-		rm_vertex ();
-		break;
-	    case TOOL_SPLIT_LINE :
-		split_line ();
-		break;
-	    case TOOL_EDIT_LINE :
-		edit_line ();
-		break;
-	    case TOOL_MOVE_LINE :
-		move_line ();
-		break;
-	    case TOOL_DELETE_LINE :
-		delete_line ();
-		break;
-	    case TOOL_DISPLAY_CATS :
-		display_cats ();
-		break;
-	    case TOOL_COPY_CATS :
-		copy_cats ();
-		break;
-	    case TOOL_DISPLAY_ATTRIBUTES :
-		display_attributes ();
-		break;
-	    case TOOL_DISPLAY_SETTINGS :
-		Tcl_Eval(Toolbox, "settings");
-		break;
-	    case TOOL_ZOOM_WINDOW :
-		zoom_window ();
-		break;
-	    case TOOL_ZOOM_OUT_CENTRE :
-		zoom_centre ( 2 );
-		break;
-	    case TOOL_ZOOM_PAN :
-		zoom_pan ();
-		break;
-	    case TOOL_ZOOM_DEFAULT :
-		zoom_default ();
-		break;
-	    case TOOL_ZOOM_REGION :
-		zoom_region ();
-		break;
-	    case TOOL_REDRAW :
-		driver_open();
-		display_redraw();
-		driver_close();
-		break;
-	    case TOOL_NOTHING :
-		   struct timespec tm;
-		   tm.tv_sec = 0;
-		   tm.tv_nsec = 200000000;
-                   nanosleep ( &tm, NULL );
-#endif
-                break;
-	i_prompt ( "Select tool");
-	/* sleep ( 1 ); */
+    /* Display the map */
+    symb_init ();
+    driver_open ();
+    display_erase ();
+    display_bg ();
+    display_map ();
+    driver_close ();
+void next_tool(void)
+    switch ( Tool_next )
+    case TOOL_EXIT :
+	G_debug (2, "Quit" );
+	end();
+	break;
+    case TOOL_NEW_POINT :
+	/* Tool_next = TOOL_NOTHING; */ /* Commented -> Draw next one once first is done */
+	new_line ( GV_POINT );
+	break;
+    case TOOL_NEW_LINE :
+	new_line ( GV_LINE );
+	break;
+    case TOOL_NEW_BOUNDARY :
+	new_line ( GV_BOUNDARY );
+	break;
+    case TOOL_NEW_CENTROID :
+	new_line ( GV_CENTROID );
+	break;
+    case TOOL_MOVE_VERTEX :
+	move_vertex ();
+	break;
+    case TOOL_ADD_VERTEX :
+	add_vertex ();
+	break;
+    case TOOL_RM_VERTEX :
+	rm_vertex ();
+	break;
+    case TOOL_SPLIT_LINE :
+	split_line ();
+	break;
+    case TOOL_EDIT_LINE :
+	edit_line ();
+	break;
+    case TOOL_MOVE_LINE :
+	move_line ();
+	break;
+    case TOOL_DELETE_LINE :
+	delete_line ();
+	break;
+    case TOOL_DISPLAY_CATS :
+	display_cats ();
+	break;
+    case TOOL_COPY_CATS :
+	copy_cats ();
+	break;
+    case TOOL_DISPLAY_ATTRIBUTES :
+	display_attributes ();
+	break;
+    case TOOL_DISPLAY_SETTINGS :
+	Tcl_Eval(Toolbox, "settings");
+	break;
+    case TOOL_ZOOM_WINDOW :
+	zoom_window ();
+	break;
+    case TOOL_ZOOM_OUT_CENTRE :
+	zoom_centre ( 2 );
+	break;
+    case TOOL_ZOOM_PAN :
+	zoom_pan ();
+	break;
+    case TOOL_ZOOM_DEFAULT :
+	zoom_default ();
+	break;
+    case TOOL_ZOOM_REGION :
+	zoom_region ();
+	break;
+    case TOOL_REDRAW :
+	driver_open();
+	display_redraw();
+	driver_close();
+	break;
+    case TOOL_NOTHING :
+	break;
-    end();
-    return 1;
 /* This function is regularly called from R_get_location_*() functions to enable GUI to kill running tool */
-int update ( int wx, int wy ) {
+void update ( int wx, int wy )
     double x, y;
     G_debug (5, "Update function wx = %d wy = %d", wx, wy);
-    i_update ();
     if ( wx != COOR_NULL && wy != COOR_NULL ) {
         x = D_d_to_u_col ( wx );
 	y = D_d_to_u_row ( wy );
         i_coor ( x, y);
-    return 1;
+void end ( void )
+    G_debug (1, "end()");
+    Vect_build_partial (&Map, GV_BUILD_NONE, NULL);
+    Vect_build ( &Map, stdout );
+    Vect_close (&Map);
+    if( 1 == G_put_window(&GRegion) )
+	G_message(_("Region restored to original extent."));
+    /* clear the screen */
+    Tcl_Eval(Toolbox, ".screen.canvas delete all");
+    exit(EXIT_SUCCESS);
Index: display.c
RCS file: /grassrepository/grass6/vector/v.digit/display.c,v
diff -u -r1.12 display.c
--- display.c	18 Feb 2007 20:16:33 -0000	1.12
+++ display.c	23 Feb 2007 02:27:34 -0000
@@ -1,8 +1,10 @@
 /* $Id: display.c,v 1.12 2007/02/18 20:16:33 glynn Exp $ */
 #include <stdio.h>
 #include <stdlib.h>
+#include <string.h>
 #include <unistd.h>
 #include <time.h>
+#include <math.h>
 #include <grass/Vect.h>
 #include <grass/raster.h>
@@ -24,13 +26,11 @@
     G_debug (2, "display_points()");
-    R_line_width ( var_geti( VAR_LINEWIDTH ) );
+    driver_line_width ( var_geti( VAR_LINEWIDTH ) );
     for(i=1; i < Points->n_points; i++) {
         G_plot_line ( Points->x[i-1], Points->y[i-1], Points->x[i], Points->y[i]);
-    R_line_width ( 0 );
-    if ( flsh ) R_flush();
+    driver_line_width( 0 );
 /* Display icon */
@@ -38,11 +38,9 @@
     G_debug (2, "display_icon()");
     G_plot_icon(x, y, icon, angle, Scale * size);
+    driver_line_width ( 0 );
 /* Display vector line
@@ -91,7 +89,6 @@
         if ( !Vect_line_alive ( &Map, line ) ) continue;
         display_line ( line, symb, 0 );
-   R_flush();
 /* Display node, color may be given but shape and size is read from symbology table,
@@ -130,7 +127,6 @@
 	if ( NodeSymb[node] == SYMB_NODE_0 ) continue;
 	display_node ( node, symb, 0);
-    R_flush();
 /* Display vector map */
@@ -155,7 +151,6 @@
 	if ( !Symb[symb].on ) continue;
 	display_line ( i , SYMB_DEFAULT, 0 );
-    R_flush();
     /* Nodes: first nodes with more than 1 line, then nodes with only 1 line,
      *   so that dangles are not hidden, and nodes without lines (points,
@@ -169,7 +164,6 @@
 	    if ( NodeSymb[i] != SYMB_NODE_2 ) continue;
 	    display_node(i, NodeSymb[i], 0);
-	R_flush();
     if ( Symb[SYMB_NODE_1].on ) {
@@ -180,33 +174,56 @@
 	    if ( NodeSymb[i] != SYMB_NODE_1 ) continue;
-	R_flush();
 /* Display bacground */
 void display_bg ( void )
+    static char w_buf[] = "GRASS_WIDTH=0000000000";
+    static char h_buf[] = "GRASS_HEIGHT=0000000000";
+    static char img_buf[GPATH_MAX];
+    static char cmd_buf[GPATH_MAX];
+    char *ppmfile = G_tempfile();
     int i;
     G_debug (2, "display_bg()");
-    driver_close();
+    putenv("GRASS_RENDER_IMMEDIATE=TRUE");
+    putenv("GRASS_TRUECOLOR=TRUE");
+    putenv("GRASS_BACKGROUNDCOLOR=0xFFFFFF");
+    sprintf(img_buf, "GRASS_PNGFILE=%s.ppm", ppmfile);
+    putenv(img_buf);
+    sprintf(w_buf, "GRASS_WIDTH=%d", (int) (D_get_d_east() - D_get_d_west()));
+    putenv(w_buf);
+    sprintf(h_buf, "GRASS_HEIGHT=%d", (int) (D_get_d_south() - D_get_d_north()));
+    putenv(h_buf);
     for(i=0; i < nbgcmd; i++) {
+	putenv((i > 0) ? "GRASS_PNG_READ=TRUE" : "GRASS_PNG_READ=FALSE");
 	if ( Bgcmd[i].on )
 	    system ( Bgcmd[i].cmd );
-    driver_open();
+    sprintf(cmd_buf, "image create photo bgimage -file {%s.ppm}", ppmfile);
+    Tcl_Eval(Toolbox, cmd_buf);
+    sprintf(cmd_buf, ".screen.canvas create image %d %d -image bgimage -anchor nw",
+	    (int) D_a_to_d_col(0), (int) D_a_to_d_row(0));
+    remove(ppmfile);
+    G_free(ppmfile);
 /* Erase */
 void display_erase ( void )
-    char command[128];
     driver_close();
-    sprintf(command, "d.erase color=white");
-    system( command ); /* It does everything and command is registered */
     driver_open();
     /* As erase must be run after each zoom by v.digit, here is good place to reset plot.
Index: driver.c
RCS file: /grassrepository/grass6/vector/v.digit/driver.c,v
retrieving revision 1.6
diff -u -r1.6 driver.c
--- driver.c	18 Feb 2007 20:16:33 -0000	1.6
+++ driver.c	23 Feb 2007 02:27:34 -0000
@@ -5,57 +5,100 @@
 #include "global.h"
 #include "proto.h"
+static char color[16];
+static int width;
+void driver_rgb_color(int r, int g, int b)
+    sprintf(color, "#%02x%02x%02x", r, g, b);
+void driver_line_width(int w)
+    width = w ? w : 1;
+static int curx, cury;
+static int driver_move_abs(int x, int y)
+    curx = x;
+    cury = y;
+    return 0;
+static int driver_cont_abs(int x, int y)
+    char buf[1024];
+    sprintf(buf, ".screen.canvas create line %d %d %d %d -width %d -fill %s",
+	    curx, cury, x, y, width, color);
+    Tcl_Eval(Toolbox, buf);
+    curx = x;
+    cury = y;
+    return 0;
+static void get_window(int *t, int *b, int *l, int *r)
+    Tcl_Eval(Toolbox, "list 0 [winfo height .screen.canvas] 0 [winfo width .screen.canvas]");
+    sscanf(Toolbox->result, "%d %d %d %d", t, b, l, r);
+    if (*b > 1 || *r > 1)
+	    return;
+    Tcl_Eval(Toolbox, "list 0 [.screen.canvas cget -height] 0 [.screen.canvas cget -width]");
+static void setup(void)
+    struct Cell_head region;
+    int t, b, l, r;
+    get_window(&t, &b, &l, &r);
+    /* Set the map region associated with graphics frame */
+    G_get_set_window(&region);
+    if(G_set_window(&region) < 0)
+	G_fatal_error ("Invalid graphics coordinates");
+    /* Determine conversion factors */
+    if (D_do_conversions(&region, t, b, l, r))
+	G_fatal_error("Error calculating graphics-region conversions") ;
 int driver_refresh (void)
-    D_setup (0);
+    setup();
     G_setup_plot (D_get_d_north(), D_get_d_south(), D_get_d_west(), D_get_d_east(),
-		                  D_move_abs, D_cont_abs);
+		  driver_move_abs, driver_cont_abs);
     return 1;
 int driver_open (void)
-    int top, bot, left, right;
     double n, s, e, w;
-    G_debug (5, "driver_open()");
-    if (R_open_driver() != 0) G_fatal_error ("No graphics device selected");
-    G_debug (5, " -> opened");
-    D_setup (0);
-    D_get_screen_window ( &top, &bot, &left, &right);
-    G_debug (2, "top = %d bot = %d, left = %d right = %d", top, bot, left, right);
+    Tcl_Eval(Toolbox, "create_screen");
-    G_debug (2, "n = %f s = %f, w = %f e = %f", D_get_d_north(), D_get_d_south(), D_get_d_west(), D_get_d_east() );
-    n = D_d_to_u_row ( D_get_d_north() );
-    s = D_d_to_u_row ( D_get_d_south() );
-    w = D_d_to_u_col ( D_get_d_west() );
-    e = D_d_to_u_col (  D_get_d_east() );
-    G_debug (2, "n = %f s = %f, w = %f e = %f", n, s, w, e );
-    Scale = (n - s) / ( D_get_d_south() - D_get_d_north() );
-    G_debug (2, "Scale = %f", Scale);
-    Xscale = ( GRegion.east - GRegion.west ) / ( right - left );
-    Yscale = ( GRegion.north - GRegion.south ) / ( top - bot );
+    setup();
-    G_debug (2, "Xscale = %f Yscale = %f", Xscale, Yscale);
-    G_setup_plot (D_get_d_north(), D_get_d_south(), D_get_d_west(), D_get_d_east(),
-    D_set_clip_window_to_map_window ();
+    n = D_d_to_u_row(D_get_d_north());
+    s = D_d_to_u_row(D_get_d_south());
+    w = D_d_to_u_col(D_get_d_west());
+    e = D_d_to_u_col(D_get_d_east());
+    Scale = (n - s) / ( D_get_d_south() - D_get_d_north() );
+    G_setup_plot (D_get_d_north(), D_get_d_south(), D_get_d_west(), D_get_d_east(),
     return 1;
 int driver_close (void)
-    G_debug (5, "driver_close()");
-    R_close_driver();
-    G_debug (5, " -> closed");
     return 1;
Index: i_face.c
RCS file: /grassrepository/grass6/vector/v.digit/i_face.c,v
retrieving revision 1.9
diff -u -r1.9 i_face.c
--- i_face.c	29 Jun 2006 02:40:49 -0000	1.9
+++ i_face.c	23 Feb 2007 02:27:34 -0000
@@ -77,13 +77,6 @@
     return 1;
-/* This function should be regularly called from C to get GUI requests */
-int i_update ( void ) {
-    G_debug (5, "i_update");
-    Tcl_Eval ( Toolbox, "update" );
-    return 1;
 /* create: 1 - create, 0 - destroy */
 void i_new_line_options ( int create ) {
     int i;
Index: line.c
RCS file: /grassrepository/grass6/vector/v.digit/line.c,v
retrieving revision 1.19
diff -u -r1.19 line.c
--- line.c	21 Feb 2007 22:15:41 -0000	1.19
+++ line.c	23 Feb 2007 02:27:34 -0000
@@ -228,13 +228,13 @@
     return 1;
-int new_line(int type)
+void new_line(int type)
-    struct new_line nl;
+    static struct new_line nl;
     nl.type = type;
-    return do_tool(new_line_begin, new_line_update, new_line_end, &nl);
+    set_tool(new_line_begin, new_line_update, new_line_end, &nl);
 /* Continue work on the end of a line */
@@ -407,11 +407,11 @@
     return 1;
-int edit_line(void)
+void edit_line(void)
-    struct edit_line el;
+    static struct edit_line el;
-    return do_tool(edit_line_begin, edit_line_update, edit_line_end, &el);
+    set_tool(edit_line_begin, edit_line_update, edit_line_end, &el);
 /* Delete line */
@@ -538,11 +538,11 @@
     return 1;
-int delete_line(void)
+void delete_line(void)
-    struct delete_line dl;
+    static struct delete_line dl;
-    return do_tool(delete_line_begin, delete_line_update, delete_line_end, &dl);
+    set_tool(delete_line_begin, delete_line_update, delete_line_end, &dl);
 /* Move line */
@@ -669,10 +669,10 @@
     return 1;
-int move_line(void)
+void move_line(void)
-    struct move_line ml;
+    static struct move_line ml;
-    return do_tool(move_line_begin, move_line_update, move_line_end, &ml);
+    set_tool(move_line_begin, move_line_update, move_line_end, &ml);
Index: main.c
RCS file: /grassrepository/grass6/vector/v.digit/main.c,v
retrieving revision 1.25
diff -u -r1.25 main.c
--- main.c	19 Aug 2006 12:52:24 -0000	1.25
+++ main.c	23 Feb 2007 02:27:34 -0000
@@ -25,7 +25,6 @@
 int Tcl_AppInit(Tcl_Interp* interp)
     int ret;
-    char buf[1024];
     G_debug (3, "v.digit Tcl_AppInit (...)");
@@ -62,27 +61,11 @@
 			      (Tcl_CmdDeleteProc*) NULL);
     Tcl_CreateCommand(interp, "c_add_cat", (Tcl_CmdProc*) c_add_cat, (ClientData) NULL,
+    Tcl_CreateCommand(interp, "c_update_tool", (Tcl_CmdProc*) c_update_tool, (ClientData) NULL,
+			      (Tcl_CmdDeleteProc*) NULL);
-    /* Init variables */
-    var_init ();
-    /* Init snap */
-    var_seti ( VAR_SNAP, 1 );
-    var_seti ( VAR_SNAP_MODE, SNAP_SCREEN );
-    var_seti ( VAR_SNAP_SCREEN, 10 );
-    var_setd ( VAR_SNAP_MAP, 10 );
     G_debug (3, "Starting toolbox.tcl");
-    sprintf(buf,"%s/etc/v.digit/toolbox.tcl", G_gisbase());
-    ret = Tcl_EvalFile(interp, buf);
-    if ( ret == TCL_ERROR) {
-	if (interp->result != NULL)
-	    G_fatal_error(_("Cannot open toolbox: %s"), interp->result);
-	else
-	    G_fatal_error(_("Cannot open toolbox."));
     return TCL_OK;
@@ -94,7 +77,8 @@
     struct Flag *new_f;
     char   *mapset;
     char   **tokens;
-    char *fake_argv[2];
+    char *fake_argv[4];
+    char toolbox[GPATH_MAX];
     G_gisinit(argv[0]);
@@ -138,13 +122,6 @@
     G_debug (1, "Region: N = %f S = %f E = %f W = %f", GRegion.north,
 	GRegion.south, GRegion.east, GRegion.west);
-    /* Check driver */
-	G_fatal_error(_("No graphics device selected"));
-    R_close_driver();
-    G_debug (1, "Driver opened");
     /* Open map */
     mapset = G_find_vector2 (map_opt->answer, G_mapset());
     if ( mapset == NULL ) {
@@ -174,47 +151,17 @@
     symb_lines_init ();
     symb_nodes_init ();
-    /* Display the map */
-    symb_init ();
-    G_get_window(&window);
-    driver_open ();
-    display_erase ();
-    display_bg ();
-    display_map ();
-    driver_close ();
-    /* Set tool */
-    Tool_next = TOOL_NEW_POINT;
     G_debug (3, "Starting Tk_Main.");
     /* Open toolbox */
+    sprintf(toolbox, "%s/etc/v.digit/toolbox.tcl", G_gisbase());
     fake_argv[0] = argv[0];
-    fake_argv[1] = NULL;
-    Tk_Main(1, fake_argv, Tcl_AppInit);
+    fake_argv[1] = "-f";
+    fake_argv[2] = toolbox;
+    fake_argv[3] = NULL;
+    Tk_Main(3, fake_argv, Tcl_AppInit);
     /* Not reached */
     exit(EXIT_SUCCESS) ;
-int
-end ( void )
-    G_debug (1, "end()");
-    Vect_build_partial (&Map, GV_BUILD_NONE, NULL);
-    Vect_build ( &Map, stdout );
-    Vect_close (&Map);
-    if( 1 == G_put_window(&GRegion) )
-	G_message(_("Region restored to original extent."));
-    /* clear the screen */
-    R_open_driver();
-    D_setup(TRUE);
-    D_clear_window();
-    R_close_driver();
-    return 1;
Index: proto.h
RCS file: /grassrepository/grass6/vector/v.digit/proto.h,v
retrieving revision 1.14
diff -u -r1.14 proto.h
--- proto.h	21 Feb 2007 22:15:41 -0000	1.14
+++ proto.h	23 Feb 2007 02:27:34 -0000
@@ -2,11 +2,15 @@
 int driver_open (void);
 int driver_close (void);
 int driver_refresh (void);
+void driver_rgb_color(int r, int g, int b);
+void driver_line_width(int w);
+void driver_plot_line(double x1, double y1, double x2, double y2);
 /* Miscellaneous */
-int update (int, int);
-int tool_centre (void);
-int end (void);
+void tool_centre (void);
+void next_tool(void);
+void update (int, int);
+void end (void);
 /* Symbology */
 int get_symb_code ( char *);
@@ -29,21 +33,21 @@
 /* Edit */
 int snap ( double *, double * );
-int new_line (int);
-int move_vertex (void);
-int add_vertex (void);
-int rm_vertex (void);
-int split_line (void);
-int move_line (void);
-int delete_line (void);
-int edit_line (void);
+void new_line (int);
+void move_vertex (void);
+void add_vertex (void);
+void rm_vertex (void);
+void split_line (void);
+void move_line (void);
+void delete_line (void);
+void edit_line (void);
 /* Attributes */
-int copy_cats (void);
-int display_cats (void);
+void copy_cats (void);
+void display_cats (void);
 int del_cat (int, int, int);
 int add_cat (int, int, int);
-int display_attributes (void);
+void display_attributes (void);
 int new_record (int, int);
 int check_record (int, int);
@@ -60,9 +64,9 @@
 void display_redraw ( void );
 /* Zoom */
-int zoom_window (void);
+void zoom_window (void);
 int zoom_centre (double factor);
-int zoom_pan (void);
+void zoom_pan (void);
 int zoom_default (void);
 int zoom_region (void);
@@ -120,13 +124,14 @@
 char *get_line_type_name ( int type);
 void set_location(int x, int y);
 void set_mode(int m);
-void get_location(int *sxn, int *syn, int *button);
 typedef int tool_func_begin(void *closure);
 typedef int tool_func_update(void *closure, int sxn, int syn, int button);
 typedef int tool_func_end(void *closure);
-int do_tool(tool_func_begin *begin,
-	    tool_func_update *update,
-	    tool_func_end *end,
-	    void *closure);
+void set_tool(tool_func_begin *begin,
+	      tool_func_update *update,
+	      tool_func_end *end,
+	      void *closure);
+void cancel_tool(void);
+int c_update_tool (ClientData , Tcl_Interp *, int, char **);
Index: symb.c
RCS file: /grassrepository/grass6/vector/v.digit/symb.c,v
diff -u -r1.6 symb.c
--- symb.c	11 Feb 2007 20:26:19 -0000	1.6
+++ symb.c	23 Feb 2007 02:27:34 -0000
@@ -110,7 +110,7 @@
     G_debug ( 2, "set color to symb %d: %d %d %d", code, Symb[code].r, Symb[code].g, Symb[code].b );
-    R_RGB_color ( Symb[code].r, Symb[code].g, Symb[code].b);
+    driver_rgb_color ( Symb[code].r, Symb[code].g, Symb[code].b);
Index: toolbox.tcl
RCS file: /grassrepository/grass6/vector/v.digit/toolbox.tcl,v
diff -u -r1.25 toolbox.tcl
--- toolbox.tcl	9 Oct 2006 01:46:10 -0000	1.25
+++ toolbox.tcl	23 Feb 2007 02:27:34 -0000
@@ -25,6 +25,29 @@
 set prompt_right [G_msg "Right mouse button"]
 set coor ""
+proc get_update_line {ox oy x y} {
+    .screen.canvas delete active
+    .screen.canvas create line $ox $oy $x $y -tags active -dash {4 4}
+proc get_update_box {ox oy x y} {
+    .screen.canvas create line $ox $oy $ox $y $x $y $x $oy $ox $oy -tags active -dash {4 4}
+proc create_screen {} {
+    if {[winfo exists .screen]} return
+    toplevel .screen
+    canvas .screen.canvas -background white -width 640 -height 480
+    pack .screen.canvas -fill both -expand yes
+    bind .screen.canvas <ButtonPress> { c_update_tool %x %y %b }
+    bind .screen.canvas <Motion> { c_update_tool %x %y -1 }
+    wm withdraw .screen.canvas
+    wm deiconify .screen.canvas
+    update
 # GVariable stores variables by key, this variables are (should be) synchronized with
 # variables in Variable array in C (synchronization should be done somehow better). Key is
 # 'name' in VAR structure in C. Variables are initialized by var_init() on startup.
@@ -236,14 +259,10 @@
 Label .coorf.prompt -width 50 -padx 3 -pady 2 -relief flat -anchor w -textvariable coor
 pack .coorf.prompt -fill x  -side left
-set destroyed 0
-bind . <Destroy> { if { "%W" == "."} { c_next_tool exit; set destroyed 1 } }
+bind . <Destroy> { if { "%W" == "."} { c_next_tool exit } }
-# Strart tool centre in C and wait until the end
+# Start tool centre in C
 c_tool_centre
-# Exit
-#puts "Exit destroyed = $destroyed"
-if { $destroyed == 0 } {
-  destroy .
+tkwait window .
+exit
Index: util.c
RCS file: /grassrepository/grass6/vector/v.digit/util.c,v
retrieving revision 1.4
diff -u -r1.4 util.c
--- util.c	21 Feb 2007 22:15:41 -0000	1.4
+++ util.c	23 Feb 2007 02:27:34 -0000
@@ -47,55 +47,105 @@
     mode = m;
+static tool_func_update *tool_update;
+static tool_func_end *tool_end;
+static void *tool_closure;
+static void end_tool(void)
+    Tcl_Eval(Toolbox, ".screen.canvas configure -cursor {}");
+    Tcl_Eval(Toolbox, ".screen.canvas delete active");
+    if (tool_end)
+	    (*tool_end)(tool_closure);
+    tool_update = NULL;
+    tool_end = NULL;
+    tool_closure = NULL;
+    driver_close();
+    end_tool();
+int c_update_tool( ClientData cdata, Tcl_Interp *interp, int argc, char *argv[])
-    R_set_update_function (update);
+    char buf[100];
+    int x, y, b;
+    G_debug (3, "c_update_tool()");
+    if ( argc < 4 )
+	Tcl_SetResult(interp,"Usage: c_update_tool x y b", TCL_VOLATILE);
+	return (TCL_ERROR);
+    if (!tool_update)
+	return TCL_OK;
+    Tcl_GetInt(interp, argv[1], &x);
+    Tcl_GetInt(interp, argv[2], &y);
+    Tcl_GetInt(interp, argv[3], &b);
     switch (mode)
     case MOUSE_POINT:
-	R_get_location_with_pointer (sxn, syn, button);
 	break;
     case MOUSE_LINE:
-	R_get_location_with_line (sxo, syo, sxn, syn, button);
+	sprintf(buf, "get_update_line %d %d %d %d", sxo, syo, x, y);
 	break;
     case MOUSE_BOX:
-	R_get_location_with_box (sxo, syo, sxn, syn, button);
+	sprintf(buf, "get_update_box %d %d %d %d", sxo, syo, x, y);
 	break;
+    if (b < 0)
+	update(x, y);
+	return TCL_OK;
+    if (b == 0)
+	end_tool();
+	return TCL_OK;
+    if ((*tool_update)(tool_closure, x, y, b))
+	end_tool();
+	return TCL_OK;
+    return TCL_OK;
-int do_tool(tool_func_begin *begin, tool_func_update *update, tool_func_end *end, void *closure)
+void set_tool(tool_func_begin *begin_fn, tool_func_update *update_fn, tool_func_end *end_fn, void *closure)
-    int sxn = COOR_NULL;
-    int syn = COOR_NULL;
-    int button;
     int ret;
+    if (tool_update)
+	end_tool();
     driver_open();
-    ret = (*begin)(closure);
+    ret = (*begin_fn)(closure);
     if (ret)
 	driver_close();
-	return ret;
-    while (1)
-	/* Get next coordinate */
-        get_location(&sxn, &syn, &button);
-	if (button == 0)
-	    break;
-	if ((*update)(closure, sxn, syn, button))
-	    break;
+	return;
+    tool_update = update_fn;
+    tool_end = end_fn;
+    tool_closure = closure;
-    ret = (*end)(closure);
-    driver_close();
-    return ret;
+    Tcl_Eval(Toolbox, ".screen.canvas configure -cursor crosshair");
Index: vertex.c
RCS file: /grassrepository/grass6/vector/v.digit/vertex.c,v
diff -u -r1.6 vertex.c
--- vertex.c	21 Feb 2007 22:15:41 -0000	1.6
+++ vertex.c	23 Feb 2007 02:27:34 -0000
@@ -159,11 +159,11 @@
     return 1;
-int split_line(void)
+void split_line(void)
-    struct split_line sl;
+    static struct split_line sl;
-    return do_tool(split_line_begin, split_line_update, split_line_end, &sl);
+    set_tool(split_line_begin, split_line_update, split_line_end, &sl);
 /* Remove line vertex */
@@ -309,11 +309,11 @@
     return 1;
-int rm_vertex(void)
+void rm_vertex(void)
-    struct rm_vertex rv;
+    static struct rm_vertex rv;
-    return do_tool(rm_vertex_begin, rm_vertex_update, rm_vertex_end, &rv);
+    set_tool(rm_vertex_begin, rm_vertex_update, rm_vertex_end, &rv);
 /* Add new vertex to line */
@@ -487,11 +487,11 @@
     return 1;
-int add_vertex(void)
+void add_vertex(void)
-    struct add_vertex av;
+    static struct add_vertex av;
-    return do_tool(add_vertex_begin, add_vertex_update, add_vertex_end, &av);
+    set_tool(add_vertex_begin, add_vertex_update, add_vertex_end, &av);
 /* Move vertex */
@@ -625,10 +625,10 @@
     return 1;
-int move_vertex(void)
+void move_vertex(void)
-    struct move_vertex mv;
+    static struct move_vertex mv;
-    return do_tool(move_vertex_begin, move_vertex_update, move_vertex_end, &mv);
+    set_tool(move_vertex_begin, move_vertex_update, move_vertex_end, &mv);
Index: zoom.c
RCS file: /grassrepository/grass6/vector/v.digit/zoom.c,v
retrieving revision 1.7
diff -u -r1.7 zoom.c
--- zoom.c	21 Feb 2007 22:15:41 -0000	1.7
+++ zoom.c	23 Feb 2007 02:27:34 -0000
@@ -96,11 +96,11 @@
     return 1;
-int zoom_window(void)
+void zoom_window(void)
-    struct zoom_window zw;
+    static struct zoom_window zw;
-    return do_tool(zoom_window_begin, zoom_window_update, zoom_window_end, &zw);
+    set_tool(zoom_window_begin, zoom_window_update, zoom_window_end, &zw);
 /* Zoom - in / out (centre unchanged) */
@@ -201,11 +201,11 @@
     return 1;
-int zoom_pan(void)
+void zoom_pan(void)
-    struct zoom_pan zp;
+    static struct zoom_pan zp;
-    return do_tool(zoom_pan_begin, zoom_pan_update, zoom_pan_end, &zp);
+    set_tool(zoom_pan_begin, zoom_pan_update, zoom_pan_end, &zp);
 /* Zoom - default region */
