[GRASS-dev] GRASS-TNG
Radek Bartoň xbarto33 at stud.fit.vutbr.cz
Fri Feb 23 06:09:23 EST 2007
On Friday 23 of February 2007 03:24:25 Michael Barton wrote:
> I agree with you that a WIKI is not a development environment. For that
> reason we have the main GRASS cvs repository AND the grassaddon subversion
> repository. The latter can be used especially for preliminary and
> experimental development. Jachym and I are using it for initial development
> of the next generation GUI for GRASS--in wx.Python (which as you might know
> is built on C++). By working there, however, even though the code is a
> complete rewrite of the GUI, others in the GRASS community can check out
> the code and try it, offer input, and join in development if they are so
> inclined. You don't need to do this at the current stage of your project,
> but should know that this resource exists.
> The main GRASS cvs also has some sections for early development code, but
> is increasingly used for mainline GRASS--once code is well-enough developed
> to be (at least optionally) included with GRASS source.
I'm aware of that.
Anyway, I changed name of project so it can be found at
http://gal-framework.no-ip.org now since gal.no-ip.org domain name is already
used.
Bc. Radek Bartoň
Faculty of Information Technology
Brno University of Technology
E-mail: xbarto33 at stud.fit.vutbr.cz
Web: http://blackhex.no-ip.org
Jabber: blackhex at jabber.cz
