[GRASS-dev] nviz volume fails: unknown shade style returned in get_drawmode
Markus Neteler neteler at itc.it
Fri Feb 23 10:23:54 EST 2007
Markus Neteler wrote on 02/21/2007 12:20 PM:
> Hi,
> in the recent restructuring of NVIZ the volume
> was apparently not tested:
> Dataset (9.3MB):
>  http://mpa.itc.it/grasstutor/data7/slovakia3d.tar.gz
> grass63 ~/grassdata/slovakia3d/PERMANENT/
> nviz el=dem500 vol=precip3d.500z50
> Loading Data
> Update elev null mask
> Loading Data
> translating colors from fp
> recalculating normals...
> Error in startup script: Internal Error: unknown shade style returned in get_drawmode
>     while executing
> "Nvol$curr slice get_drawmode"
The problem is in
visualization/nviz/src/map_obj.c
line 833 etc read like this (G_debug() I have added for me only):
    /* Parse mode returned for shade style and surface style */
    G_debug(0,"mode: %d",mode);
    if (mode & DM_GOURAUD)
    strcpy(shade, "gouraud");
    else if (mode & DM_FLAT)
    strcpy(shade, "flat");
    else {
    Tcl_SetResult(interp,
              "Internal Error: unknown shade style returned in
get_drawmode",
              TCL_VOLATILE);
    return (TCL_ERROR);
Result is:
D0/0: mode: 2308
get_drawmode
    while executing
In
include/gsurf.h
are definitions for:
/* surface display modes */
#define DM_GOURAUD   0x00000100
#define DM_FLAT      0x00000200   /* defined for symmetry */
#define DM_FRINGE    0x00000010
#define DM_WIRE      0x00000001
#define DM_COL_WIRE  0x00000002
#define DM_POLY      0x00000004
#define DM_WIRE_POLY 0x00000008
#define DM_GRID_WIRE 0x00000400
#define DM_GRID_SURF 0x00000800
Not sure what mode = 2308 means...
Markus
