[GRASS-user] Re: [GRASS-dev] FW: list GRASSLIST: List Message Rejected
Markus Neteler neteler at itc.it
Sat Feb 24 00:51:03 EST 2007
On Fri, Feb 23, 2007 at 05:40:50PM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > we do not want to remotely destroy the old Baylor site :-)
> > So, we have no control over the old mailing list. It seems to run
> > unmaintained.
> Presumably, you do have control over whether or not that list is
> subscribed to this one. I believe that Michael is suggesting that you
> remove the subscription. I would agree; that list is essentially dead,
> and most of us are no longer subscribed to it.
OK:
successfully removed from grassuser*grass.itc.it:
    * grass at baylor.edu
    * grasslist at baylor.edu
    * grasslistuser at grass.itc.it
    * grassuser-bounces at grass.itc.it
This means that mails posted to the old, unused Baylor list
no longer reach the active GRASS user list here. That hopefully
reduces confusion.
Markus
