[GRASS-dev] New v.digit
Sat Feb 24 02:03:22 EST 2007
Markus Neteler wrote:
> What's the idea of the "-n" flag?
To create a new map. Are you asking why it doesn't just do this
automatically if the map already exists? Possibly so that you don't
accidentally create a new map if you make a mistake entering the name
of an existing map.
> I could not find out the last
> years :-) Can we disable it (in the common "deprecated" way)?
Ignoring it would be trivial; just remove the "if ( new_f->answer ) {"
from around the code which creates a new map.
