[GRASS-dev] New v.digit
Sat Feb 24 14:19:08 EST 2007
Markus Neteler wrote:
> > > PPS: A wish: having "close" buttons in all "Settings" tabs would
> > >      be great
> > Close buttons in *tabs*? For what purpose?
> Right, I meant a close button for the entire window
> or something reasonable.
> Take for example the "Background" tab:
> - click "Add command"
> - write "Winnie The Pooh"
> - then? Kill the entire settings window - not really obvious
> ("Winnie The Pooh" is then silently ignored/disappears)
> I would expect some "confirm" thing or so or a "Done"
> button below all tabs.
Ah, an "Ok" button (apply changes and close window).
Add it to the RT as a wish; for now, I would rather stick to fixing
anything which broke as a result of switching from libraster to Tk.
