[GRASS-dev] Re: g.rename consolidation
Maris Nartiss maris.gis at gmail.com
Tue Feb 27 04:37:18 EST 2007
just to illustrate my point, that current way of notifying user about
process run is not intuitive.
Take look at this screenshot:
http://www.gisnet.lv/ggmlinux/Grass-25.png
Is r.watershed still runing? (Those, who know GRASS enough, will
notice, that "RUN" button is enabled - r.watershed is not running
anymore) Is r.watershed finised it's run with success? And what would
happen, if gis.m output window is covered (behind) other windows? I
have moved output window to top, but normaly it would be behind all
other gis.m  windows.
r.watershed isn't worst module - just run some of v.* modules, that
require rebuilding tolopgy and picture will become worse, as output in
gis.m output window just scrolls up with every line and that progress
bar/runner just goes far, far away.
Just my 0.002,
Maris.
2007/2/27, Michael Barton <michael.barton at asu.edu>:
> Both of these sound like good ideas.
> Michael
> On 2/26/07 10:28 PM, "Hamish" <hamish_nospam at yahoo.com> wrote:
> >>> Glynn Clements wrote:
> >>>> Tcl knows when a process finishes by the "eof" from the stream
> >>>> identifier which "open |..." returns. There's no reason why the
> >>>> Tcl/Tk GUI can't add something to the gronsole when the command has
> >>>> finished, regardless of whether or not the module uses
> >>>> G_done_message().
> > H:
> >>> then let's do it!
> > Michael Barton wrote:
> >> Isn't this what Cedrick's code already does? When a module starts, a
> >> little running person icon shows up in the output window (i.e., the
> >> module is "running"). When the module finishes, the little runner goes
> >> away.
> > I'd prefer to see this in the module's gui window "Output" tab, not the
> > gis.m output console.
> > Or at minimum replace the spent runner with a green tick mark if the
> > module exited with a successful exit code.
> > Hamish
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
