[GRASS-dev] [grass-code I][314] r.in.xyz: estimated region half unit off
Maciej Sieczka tutey at o2.pl
Tue Feb 27 18:34:42 EST 2007
Hamish wrote:
> This is not a bug, -s scan extent of points results are correct.
> r.out.xyz outputs points at cell centers, which are half a cell inside
> of the region boundary (outer edge of cells).
> r.in.xyz -s just reports what is in the input points file, it doesn't
> try and merge that with the current region settings.
<snip>
> This is the approach the example in the r.in.xyz help page takes
> already.
> Nothing more to do. Closing bug.
Hamish,
You are right. I should have thought more of it before submitting. Sorry.
Maciek
