[GRASS-dev] r3.univar and r.univar
Sören Gebbert soerengebbert at gmx.de
Tue Feb 27 19:28:29 EST 2007
thanks for testing!
Because of the heapsort code issue, i have implemented a new version of
r3/r.univar.
The heapsort code is now based on a GPL implementation which i have
found in the net and it seems to work.
http://www.fh-augsburg.de/informatik/vorlesungen/c_cplus/tutorial/cyris/c-kurs16.htm
The original author of the heapsort code is noticed in the code.
The latest version is available here:
http://www-pool.math.tu-berlin.de/~soeren/grass/modules/r3.univar.tar.bz2
Best regards
Soeren
Martin Landa schrieb:
> Hi,
> 2007/2/27, Sören Gebbert <soerengebbert at gmx.de>:
>> Dear devs,
>> i have merged the code of r.univar and r3.univar.
>> Please test the new modules and if no errors occure, i will replace
>> the current r.univar code with the new one.
>> The code:
>> includes r3.univar and r.univar.
> I slightly tested the new r.univar/r3.univar module, no errors
> occurred. From my point of view, the current r.univar code can be
> replaced.
> Martin
