[GRASS-dev] GRASS inefficiency and FFTW
stefano de paoli dplsfn at yahoo.it
Wed Feb 28 18:06:18 EST 2007
> The problem is that we couldn't then use other
> people's GPL code, as
> we wouldn't be distributing the end result under the
> GPL.
> Also, what does the "use within GRASS only"
> restriction on the NR code
> actually mean for a GPL'd project? If someone takes
> the GRASS code and
> starts modifying it, at what point does their
> version cease to be
> "GRASS"?
I may be mistaken, but you would also have lost the
right to use the GPL at all if the NR code remained in
GRASS.
Is that true?
> Glynn Clements <glynn at gclements.plus.com>
___________________________________
L'email della prossima generazione? Puoi averla con la nuova Yahoo! Mail:
http://it.docs.yahoo.com/nowyoucan.html
