[GRASS-dev] Re: Behavior of explore mode in GIS Manager
Cedric Shock cedricgrass at shockfamily.net
Tue Jan 2 11:21:35 EST 2007
Michael,
> Essentially, it is changing so that a constant number of grid cells are
> represented in the display window.
> Is this the way we want zooming to work in this special mode? If so, we
> need to change the mouse over help to make sure this is clear. If not, we
> need to change how explore mode works so that it does not change
> resolution. I can see advantages and disadvantages of each.
This was very deliberate. Explore mode does two things:
Makes the region displayed fill the window and
Makes the region one cell per pixel on the display device.
The solution is more documentation or ...
I actually considered two separate toggle buttons when I designed this, one
for filling the screen and one for automatic resolution changes. Another
interesting behaviour is the one you described, "a constant number of grid
cells are represented in the display window", but it is slightly less obvious
how to use.
--Cedric
