[GRASS-dev] v.in.dxf and modified version of G_percent
Mon Jan 8 09:12:37 EST 2007
Jachym Cepicky wrote:
> in read_dxf.c (v.in.dxf) there is function big_percent(). This function
> prints information about progres while import. big_percent is defined
> like
> int big_percent(unsigned long n, unsigned long d, int s)
> while G_percent
> int G_percent (int n,int d,int s)
> IMHO v.in.dxf should use G_percent too. What kind of approach is the
> best:
>     - Rewrite G_percent, so it uses long integers on input
>     - New function G_percent_big for cases like this
>     - Nothing, using G_percent directly will not cause any problem
I suggest taking the first approach.
