[GRASS-dev] g.list -a
Martin Landa landa.martin at gmail.com
Sat Jan 13 14:15:40 EST 2007
Glynn,
I committed changes to CVS.
Once more thanks a lot for the help and valuable feedback.
Martin
2007/1/13, Glynn Clements <glynn at gclements.plus.com>:
> Martin Landa wrote:
> > > +       if (G_parser(argc, argv))
> > > +               fprintf (stderr, _("\nWhere %s is one of:\n"), element->key);
> > > +               show_elements();
> > > +               exit(EXIT_FAILURE);
> > > If G_parser() fails, the program should just call exit(EXIT_FAILURE);
> > > G_parser() will print an error message detailing why it failed.
> > Yes, but the function show_elements() provides the user additional
> > information why it failed. Would you like to remove it (maybe I have
> > missed something)?
> > Where type is one of:
> >   rast      (raster files)
> >   rast3d    (raster3D files)
> >   vect      (binary vector files)
> >   oldvect   (old (GRASS 5.0) binary vector files)
> >   asciivect (ascii vector files)
> >   icon      (paint icon files)
> >   labels    (paint label files)
> >   sites     (site list files)
> >   region    (region definition files)
> >   region3d  (region3D definition files)
> >   group     (imagery group files)
> >   3dview    (3D view parameters)
> The built-in error handling will display the following message:
> Error: value <foo> out of range for parameter <type>
>        Legal range: rast,rast3d,vect,oldvect,asciivect,icon,labels,sites,region,region3d,group,3dview
> IMHO, this is sufficient. Note that the type descriptions *aren't*
> shown if you use "g.list help", only if there is a parsing error
> (which isn't limited to an invalid value for the type= option).
> OTOH, I'm not really that bothered about this issue; assuming that it
> compiles okay, I'll commit your latest version.
> > > > > lib/do_list.c doesn't need to change; just have cmd/list.c call
> > > > > do_list() once for each type.
> > > > I think that fn do_list() have to be rewritten because of the -f flags
> > > > (calling of execl() fn) ?
> > > No; do_list() can remain untouched, while the handling of -f should
> > > remain essentially the same, except that it should use G_spawn()
> > > instead of execl().
> > Ops, you are right. Maybe I need study GRASS API more deeply:-) Thanks
> > for pointing to the G_spawn! Now it works.
> FWIW, I've added a native Windows version of G_spawn(), although I
> haven't had chance to test it yet.
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
