[GRASS-dev] v.to.rast with category label support
Helena Mitasova hmitaso at unity.ncsu.edu
Sun Jan 21 14:51:46 EST 2007
While working on a replacement data set for spearfish
I found that when we convert from vector data to raster there is no
option to add labels
so it needs to be done manually after the conversion.
But there is only r.support to do that and it would be hard to use if
you have
large number of categories and it is practically unusable if the
category numbers are large (e.g. I have only 5 zipcodes ranging from
27511 - 27606
and r.support wants me to start with category 1).
I rarely have to use this for my research work and if it is needed
I just edit the cat file, but that is not a good solution.
currently we have:
v.to.rast input=name output=name [use=string] [column=name]
[layer=integer] [value=float]
would it be possible to add
uselabel= with options at least: attr,cat, although some people may
find the others useful: val,z,dir
column= this one does not have to be numeric for labels
Or is there any other way how to handle the raster map cat labels
that I am missing?
Helena
P.S. Markus, Brad I am posting this to the list as it involves vector
data conversion
rather than just import.
Helena Mitasova
Dept. of Marine, Earth and Atm. Sciences
1125 Jordan Hall, NCSU Box 8208,
Raleigh NC 27695
http://skagit.meas.ncsu.edu/~helena/
