[GRASS-dev] File based GRASS batch processing?
Florian Kindl florian.kindl at uibk.ac.at
Mon Jan 22 11:45:35 EST 2007
On Jan 22 [17:26], Markus Neteler wrote:
> > I use VNC as a workaround: Start vncserver with -localhost option,
> > Login with ssh -X and start vncviewer. Then I do the grass job on the
> > vnc desktop, which isn't affected by my logging off.
> > Is this an option for you?
> No, any VNC connection is eaten by our firewall.
That's why I tunnel it through ssh. Is that port open?
> > However, the batch processing mode would be good for at/cron jobs, too.
> Right. That's why I would prefer a totally decoupled solution.
+1
Is certainly preferrable :)
\f
Florian Kindl
Institute of Geography
University of Innsbruck
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070122/88317f75/attachment.bin
