[GRASS-dev] Re: What is a binary executable doing in CVS?
Bernhard Reiter bernhard at intevation.de
Wed Jan 24 04:10:22 EST 2007
On Wednesday 24 January 2007 00:32, Markus Neteler wrote:
> as CVS admin, could you help us with this problem before it
> becomes too messy?
sure...
> On Tue, Jan 23, 2007 at 07:04:23PM +0000, Glynn Clements wrote:
> > Benjamin Ducke wrote:
> > > > Why are we including what appears to be a MacOSX binary for GNU make
> > > > in CVS (gem/skeleton/macosx/bin/make)? We wouldn't normally store
> > > > binary executables in CVS.
> > > Oops, that's a leftover from pre-CVS development of GEM.
> > > Just delete it if you want.
> > Unfortunately, "cvs remove" won't suffice, because the file will still
> > be available from CVS using an explicit revision.
> > We either need to add the corresponding source code to CVS (a tarball
> > would suffice, but it needs to be the correct version), or have
> > someone manually remove the ,v file from the repository.
removed directory gem/skeleton/macosx from the repository.
Bernhard
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070124/90ed2b0a/attachment.bin
