[GRASS-dev] v.to.rast with category label support
Maciej Sieczka tutey at o2.pl
Thu Jan 25 14:21:21 EST 2007
FYI, there are 2 threads in the old BT concernig this:
v.to.rast: assign the cats and labels in the output raster
https://intevation.de/rt/webrt?serial_num=3045
update v.to.rast to include suport for GRASSRGB column
https://intevation.de/rt/webrt?serial_num=3769
BTW, there are 3 bugs in v.to.rast reported and documented:
use=dir: some nans are present in the output instead of nulls
https://intevation.de/rt/webrt?serial_num=5163
wrong cells rasterised often:
https://intevation.de/rt/webrt?serial_num=4488
contradictory errors reported when column doesn't exist in input
https://intevation.de/rt/webrt?serial_num=4480
Maciek
