[GRASS-dev] Re: Nviz animation wish
Helena Mitasova hmitaso at unity.ncsu.edu
Thu Jan 25 18:32:32 EST 2007
On Jan 25, 2007, at 11:51 AM, William Kyngesburye wrote:
> On Jan 25, 2007, at 8:19 AM, Helena Mitasova wrote:
>> Michael - there is a file sequencing tool for that in nviz - I
>> have been doing it for years (I also
>> had some of it at your workshop), just check my website.
>> My slides for the lausanne workshop should have a description how
>> to do it along
>> with a sample data set. I need to run now but I can write you more
>> later.
>> It may be broken in the latest CVS but it worked well in 6.1
> I was going to mention this also.  It looks like it can make a
> series of ppm images, or an mpeg if GRASS was built with ffmpeg
> support.
nviz will create series of rgb files - I used moviemaker to make them
into movies on SGI.
I had troubles to create decent animations after moving to PCs - as
mpeg movies weren't
very good for small number of frames so I used gifmerge to create
animated gifs.
That was until somebody suggested convert (thank you million times, I
don't remember who it was)
- it has many options and you can create high quality
animated gifs from series of rgb images (or images in other formats)
http://linux.about.com/od/commands/l/blcmdl1_convert.htm
Here are the workshop slides that describe how to do the animations
from series of raster maps
in nviz including some examples:
http://skagit.meas.ncsu.edu/~helena/grasswork/foss4g/
FOSS4G06WKSVisual4anim.odp (34Mb)
Helena
> And this is where I have issues.  I've been wrestling with this for
> a while, trying to get a usable ffmpeg library on Mac OS X.
> Because of the VERY unstable nature of the ffmpeg project (a
> perpetual beta), it's hard to get something that works at any given
> time.  This probably applies to more than just OSX.  Building a
> universal binary is more difficult because of different processor
> optimizations.  Nobody makes binaries for the ffmpeg libraries,
> just the program.  At least on OSX, and I don't want to resort to
> Fink or Darwinports.
> As an alternative to directly in nviz, there is the r.out.mpeg
> module.  You could create the ppms in nviz, then run those thru
> r.out.mpeg.
> But that has a similar problem - no Mac binaries for the mpeg-
> encode program that it uses.  And ancient code - I haven't tried
> building it yet, but I expect problems.
> A possibility would be to rewrite the r.out.mpeg module to use the
> ffmpeg program or other mpeg encoder, which has readily available
> binaries.  Or just run them manually thru ffmpeg.
> A question about the ffmpeg support - is it limited to just the
> mpeg-1 output, or can it use any format supported by ffmpeg?
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> First Pogril: Why is life like sticking your head in a bucket
> filled with hyena offal?
> Second Pogril: I don't know.  Why IS life like sticking your head
> in a bucket filled with hyena offal?
> First Pogril: I don't know either.  Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
