[GRASS-dev] Holiday GUI updates to GRASS
Mon Jan 29 01:14:09 EST 2007
Michael Barton wrote:
> I just committed a number of GUI updates to GRASS which will hopefully
> make some people happy for the holidays.
> 1. The title bar on the map layer window looks a bit nicer
> 2. You can now select panel options by clicking the icon/button in the
> map layer window. Previously, you had to click the text.
> 3. I did a complete makeover to the EPSG projection setting GUI. There
> is now a search engine that allows you to search for any text string,
> will automatically grab the associated EPSG code, and put it into the
> EPSG code entry window.
> 4. I put all the define new region code into the tcltk script (it was
> in a separate bash script) so that it is now Windows-compatible (I
> hope). Some of this code will go away with planned improvements to
> g.proj.
> 5. When you define a location using the EPSG module, it automatically
> updates the locations list so that you don't have to restart GRASS to
> see the new location.
> 6. I did a few cosmetic improvements to the main startup window
> (button placement and consistent relief height).
brilliant on all counts.
Hamish
