[GRASS-dev] r.li (landscape indices)
Roberto Antolin roberto at geomatica.como.polimi.it
Tue Jan 30 08:29:00 EST 2007
Hi all,
>These new modules are longer (21,18,15):
> v.lidar.edgedetection
> v.lidar.growing
> v.lidar.correction
>suggestion:
>v.lidar.edgedetection -> v.lidar.edgedetect or v.lidar.edge ?
> (it is a shame to change as "edgedetection" explains the module well)
I don't like to loose the name either. v.lidar.edgedetect is for sure a
good name too since it still explains the module but it is still 18 char
long. So, I think there is only one solution: v.lidar.edge
>v.lidar.growing -> v.lidar.classify
> (I think "region growing" is misleading & conflicts with GRASS's common
>  use of "region" for raster bounds/resolution; -ing is bad grammar)
Yes, that's probably the best name.
>v.lidar.correction -> v.lidar.filter
The true lidar filter is composed by the three modules all together. So,
I think this is a bad name.
Maybe v.lidar.correct as Brad suggested is better.
Saludos,
Roberto.
Roberto Antolín Sánchez
Politecnico di Milano – Polo Regionale di Como
(Laboratorio di Geomatica V2.8)
Via Valleggio, 11 – 22100 Como, Italy
tel: +39 031 332 7533 || fax: +39 031 332 7519
email: roberto.antolin at polimi.it
