[GRASS-dev] v.what.rast patch: where statement added
Markus Neteler neteler at itc.it
Tue Jan 30 12:27:43 EST 2007
I have a map of tick sampling sites and a few sites
are lacking the elevation. Only those I want to update
from a DEM which is easily done with v.what.rast.
I have added a where= statement to the program (patch
attached) which works as it is rather trivial.
The only issue is that the program states at the end:
25 categories loaded from table
24 categories loaded from vector
0 categories from vector missing in table
0 duplicate categories in vector
24 records updated
0 update errors
In case the user uses   where="height=0"
then "XX records updated" is wrong as it is calculated
on the base of geometry, not DBMI events.
My patch contains a dirty deactivation of this message
in case where= is used. Of course it would be nicer to
see the actual number there.
Any ideas?
Markus
? OBJ.x86_64-unknown-linux-gnu
Index: main.c
RCS file: /grassrepository/grass6/vector/v.what.rast/main.c,v
retrieving revision 1.19
diff -u -r1.19 main.c
--- main.c	28 Oct 2006 20:33:34 -0000	1.19
+++ main.c	30 Jan 2007 17:17:32 -0000
@@ -49,7 +49,7 @@
     DCELL *dcell;
     double drow, dcol;
     char buf[2000];
-    struct Option *vect_opt, *rast_opt, *field_opt, *col_opt;
+    struct Option *vect_opt, *rast_opt, *field_opt, *col_opt, *where_opt;
     int Cache_size;
     struct order *cache;
     int cur_row;
@@ -96,6 +96,8 @@
     col_opt->required   = YES ;
     col_opt->description= _("Column name (will be updated by raster values)") ;
+    where_opt = G_define_standard_option(G_OPT_WHERE);
     if (G_parser(argc, argv))
       exit(EXIT_FAILURE);
@@ -309,10 +311,14 @@
 	db_append_string ( &stmt, buf );
-	sprintf (buf, " where %s = %d", Fi->key, cache[point].cat);
+        sprintf (buf, " where %s = %d", Fi->key, cache[point].cat);
-        G_debug ( 3, db_get_string (&stmt) );
+	/* user provides where condition: */
+	if (where_opt->answer) {
+	    sprintf(buf, " AND %s", where_opt->answer);
+	    db_append_string ( &stmt, buf );
+        G_debug ( 0, db_get_string (&stmt) );
 	/* Update table */
 	if ( db_execute_immediate (driver, &stmt) == DB_OK ){
@@ -332,7 +338,7 @@
     G_message ( _("%d categories loaded from vector"), point_cnt );
     G_message ( _("%d categories from vector missing in table"), norec_cnt );
     G_message ( _("%d duplicate categories in vector"), dupl_cnt );
-    G_message ( _("%d records updated"), update_cnt );
+    if (! where_opt->answer) G_message ( _("%d records updated"), update_cnt );
     G_message ( _("%d update errors"), upderr_cnt );
     exit(EXIT_SUCCESS);
